STM l293E H-bridge/driver?
So right now im trying to wire up this H-bridge its pretty much the same thing as an l293D except it can handel 1-2amps and its a 20pin dip. Last nigh I bread boarded the thing just like an l293D would be wired up but I left the extra sense pins alone. The h-bridge functionality seemed fine, I set the chip for 5 volt logic and tested it buy connecting input 1 to 5v then input 2 to 5v the motor flipped polarity etc. My supply was 9.6v and for some reason I was only getting three volts to the motor with no PWM signal or anything just a straight 5v to hi.
Well today I wanted to wire two in parallel because im acually going a little over 2 amps when the motor stalls when running in higher voltages. Anyways I figured maybe the sense pin was causing the voltage drop or something I looked through the data sheet and couldnt figure out what it does, there was a schematic with it hooked up to opamps and a bunch of stuff but thats way more than Im trying to do. I also realized they had diodes around the motor, All the 293d schematic dont have the diodes im guessing becuase they have built in clamping diodes, im not sure if this chip need them or not. I have some other drivers that I wanted to use but they need 1n418s all i have is 1n4001s and a buch of glass diodes that have less voltage drop but dont know if there fast switching.
My circuit also stopped working after a bit, im not sure if I killed the chip somehow it never got too hot and when I replaced the vhip with a new one it still wasnt working so im not sure what was going on maybe a problem with one of the wires. I have two new chips wired in parrallel ready to hook up but id really appreciate it if someone could maybe tell me what the sense pin does and give me some advice about what may have been giving me a crazy 6v drop
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000058.pdf
In regards to the voltage drop you may be using a 9.6V pack but when you measured the lower voltage was that just at the motor or did you also take a reading again back at the battery? If you are using an old battery it may show almost 9.6V but under a real load it can drop quite a bit. You may be surprised to find out that under load the battery itself only puts out a low voltage.
You may have an open or un-connected ground, etc. We'd need a schematic of exactly how you wired it and maybe even a picture to try and troubleshoot it.
Secondly I set these up in parallel and then stalled the motor I read 2.5amp on my meter. in a parallel set up I should be able to get 2-4 amps, the chips both heat up pretty evenly too, not like one is taking all the load while the other does nothing, im going to guess these arent BJT. So if you were running a 2 to 4 amp hbridge at 2.5 amps for maybe 20 seconds would it be normal for it to get hot enough to start burning you? I have plenty of sinks and fans that should work but I want to make sure that what im experincing is normal before calling it a day
Might want to check your propeller to make sure it's still alive in the sense that it can still drive the pins to the 293 ... I just had two 293D's powered with a 12V supply on Vcc2 fail because of a dumb mistake on my part.... consequently their failure caused an over voltage on the Propeller I/O pins driving the enable and controls. The Propeller Identifies, but the pins no longer work as an output. ... another dumb mistake on my part. .... time for some current limiting resistors.
