Upgrading the Propeller Demo Board's EEPROM
Okay, I am really enjoying PropForth, but would like to take advantage of more EEPROM by removing the existing 32K from my Propeller Demo Board and replacing it with a larger one. I am sure I can locate 64K, but I am wondering how large is available that is compatible to the existing chip's footprint.
After all, it I am going to change it, I might as well go big.
Edit: I'm pretty sure this (128K) one will work.
I'm almost sure it is. The upper 64K is accessed by adding one to the address. This particular chip only has two address pins instead of the usual three. I'm almost positive I've used a DIP version of this chip with a Prop before without any problems.
I know Mike Green has discussed this chip on the forum before. Mike are you online?
