Position Index Sensor
I'm still trying to figure out an index circuit for the ceiling fan POV project,
Magnetics was and interesting idea, but cumbersome in the execution.
I got a couple working but the close proximity required for
correct operation is, in this case, a stopper.
So, moving on, does anyone have an LED/photoransistor
combination they could recommend?
This will be for a reflective setup not more than 2 feet in distance.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PEKitLabs-v1.2.pdf
Actually, that's why I was asking here...
the IR LED and phototransistor are not called out by name...
Part numbers?
http://www.parallax.com/Store/Sensors/ColorLight/tabid/175/CategoryID/50/List/0/SortField/0/Level/a/ProductID/177/Default.aspx
http://www.parallax.com/Store/Sensors/ColorLight/tabid/175/CategoryID/50/List/0/SortField/0/Level/a/ProductID/178/Default.aspx
Reading the datasheet of the suggested component (PNA4601M) I'd noted a minimum 400uS steady detection (16 pulses @ 38 kHz) or its absence to ensure a valid output, unless I was drove to a mistake by the figures in there. I do not know the angular velocity that is to be used in the project to ensure the proposed effect but it seems to me that a outter slotted disc (like a slightly "reworked" ancient hard sectored floppy disc, Heathkit H-89 as a mere example) and a slotted optical switch could do the job in a very efficient manner. The disc could be secured to the axle and the optical switch could be fixed to the upper cover dish of the fan. If balancing is to be concerned it could be easily attained by the use of small masses or, in case of exact detection of blade positioning, by a "one switch per blade" schem. The outter edge of the disc could be cut shaped to allow the generation of any number and position of pulses one can imagine, logicaly taking in account the physical limits and precision of the cuts.
I hope it helps a little.
Yanomani
Maybe CW or CCW rotation detection could be a useful bonus of having two or more detectors.
Yanomani
Uh, nope, Not this time.
That's kind of the idea, but without the need for close tolerances.
Just a plain old IR LED (of some given wavelength) and a photo transistor that can "see" it.
No data encoding involved for this part.
Hmmm, these same parts could be used to make a reflective tachometer.
Then I'd actually know how fast the thing is turning.
But I'm guessing 100 to 300 RPM should be in the ball park.
3 to 10 microseconds per rotation?
My thought was a band of black tape around the motor housing and
a small spot of reflective tape on that to act as the index target.
All I need is to see the pulse.
I was thinking if would be helpful to time a couple of revolutions then take that and
work out the dot clock rate. It seems like it could be more RPM tolerant that way.
Balancing something turning like that is always an issue.
I get better results if things are all grouped together rather than strung out all over the place.
Just a board and battery is pretty easy to calculate.
But add a couple more parts and wire and it gets messy trying to figure out all the arms and moments.
Do-able, but messy.
Exactly, Phil.
But I'm not looking for a communications channel, just a spot...
Copy that.
A good starting place?
http://www.sbprojects.com/knowledge/ir/index.php
Assuming, to be conservative, that the circuit will be made to detect something like 32 pulses of 38 kHz (~840 uS) @ worst case 300 RPM (200 mS), then you should use at least 1.5 degree of reflective tape over the black one. Also the right angular alignement between the emitter and the receiver should be ensured to attain a reasonable beam incidence. I hope dust don't pile over the lenses demanding a constant cleanup.
Yanomani
