Question about power supply filter capacitors
RDL2004
I'm thinking about building a new power supply and I ran across this new Panasonic EEU-FR series at Mouser. I'm wondering if there's any good reason to not use low ESR electrolytics for the filter capacitors?
Does the Panasonic data sheet for said beasties discuss anything of the sort?
http://www.illinoiscapacitor.com/pdf/Papers/low_ESR_fact_or_fiction.pdf
Generally, low ESR capacitors are better quality than regular capacitors.
In power supply applications low ESR caps tends to exhibit less ripple voltage.
The thing about needing larger rectifier diodes is not true.
Yes, the peak charging current can be higher but for a shorter period of time.
Rectifier diodes can take much higher surge currents than their steady state
current rating.
You will not notice any difference using low ESR capacitors.
Further, the peak charging current is probably limited by other resistances
in the power source and not by the low ESR in the capacitor.
If you want to use low ESR capacitors they will directly replace
standard ESR capacitors in power supply circuits.
Duane J
(thanks to Dave for that useful link and to Duane for the good information)
...and, you're welcome! Happy to help.
