Need to repair an acrylic water phantom
frank freedman
Maybe someone out there has run across something similar (Erco maybe?).
I have a 20CM water phantom that is about 20 years old and it now leaks at a seam. I have separated it the rest of the way, and would like to know if anyone knows of a bonding material that can reseal and bond the pieces back together. Do the surfaces need to be perfectly smooth, .. etc.
Frank
Frank
If it needs to be really strong like a fish aquarium then a specialty acrylic epoxy might be needed.
Size, moving range and motor positions optimized for TomoTherapy® Hi·Art® Systems
3D stainless steel moving mechanism with high speed stepper motors
The MP3-T water tank is optimized for the use with TomoTherapy Hi·Art treatment units with dynamic arc techniques. Once adjusted to the therapy unit, the water tank has not to be moved to cover all measuring tasks. The 20 mm thick acrylic walls do not bulge during prolonged period of use and feature etched lines for precise tank alignment. Precision stepper motors are mounted on a position for the use in the TomoTherapy Hi-Art gantry. They provide for high detector moving speed of 50 mm/s and high positioning accuracy of ± 0.1 mm. In contrast to analog drives, stepper motor drives do not require regular recalibrations. To operate the tank, MEPHYSTO mc2 software and TBA electronics are required. "
I still have no idea what a water phantom is, except that it looks like an aquarium with "attachments." (But thank goodness it's a "3D water tank." Heaven knows what a 2D or 4D water tank would look like!)
I looked up some waterproof glues this one seemed like it might work.
If it was solvent-welded, you need some Weld-On #4 acrylic solvent. Ethylene dichloride works well too if you're in a lab environment and have it around. The solvent just flows in via capillary action and it has no gap-filling capability at all. The solvent literally dissolves the two surfaces and they flow together, with the solvent slowly diffusing away. Weld-On 16 is basically the same as #4 except it has acrylic dissolved in it to make it thick. It works, but it can be hard to get into a joint unless the whole side came off and it's horribly messy. If you can get a decent looking joint with it you're doing better than I am.
If the tank was originally solvent welded you can probably still use silicone, but not the other way around. If they used silicone before, use it for the repair. If you do a solvent weld that doesn't look trustworthy, you can add a bead of silicone to provide a seal. I'd fill it and let it sit for a day or two to make sure it will hold before using it.
Incidentally, "phantom" is a generic term for something that takes the place of tissue in a scanner (e.g. CT or MRI) or radiation treatment system (gamma, proton, etc). They're used for calibration, testing, research, etc. They often use water because tissue is mostly water. Sometimes acrylic blocks or shapes or a special cross-linked polystyrene called Rexolite are also used. There are fancy ones that can hold sensors or pieces of radiographic film for special purposes.
[edit]: I've also heard chloroform works well, but I've never tried it. Adequate ventilation is obviously in order with any solvent.
That's an accurate, if overly commercial description. The tank has "attachments" to hold probes, which are then moved by the stepper motors from the entrance window (where the radiation enters the tank) towards the opposite side so measurements are taken with increasing water thickness, simulating increasing tissue thickness. The idea is to get the relationship between radiation dose and tissue thickness so that when a specific organ or region in the body needs to be treated, the clinician or physicist can adjust the dose accordingly. The etched lines and such are just because in radiation treatment systems, phantoms (or patients) are typically positioned using laser cross-hair references.
Great comment re the 2D/4D water tank. I spilled my tea laughing at that.
As tl the 20 cm water phantom, it is used for testing CT systems.
edit: Technically speaking, I probably should have said adhesives instead of "gluing"
Thanks for all the great info,
Frank
