Problems matching npn, pnp
lardom
I'm trying to design a 3 1/2 H-bridge circuit to do some tests on a sensorless bldc motor. It would have been ideal to find high side and low side transistors with matching specs...that I could find at RadioShack. Building an H-bridge is a new experience for me. I hope that 'high side / low side' emitter-collector outputs match if I choose biasing resistors for the pnp transistor which has lower specs.For those who've built H-bridges are the differences between a pnp / npn a big problem?
In the schematic I'm using 6 2N2222 npn's to switch high-side TIP42 and low-side TIP31 power transistors.
http://www.futurlec.com/TransPowerTIP.shtml
BTW, using darlingtons doubles the voltage drop of the item. Normal power transistors will have a saturation voltage drop listed of 1 - 2 volts, while darlingtons will have 2 - 4 volts drop at saturation.
You will notice that the TIP series all have the matching PNP/NPN pair cross-referenced.
But the really good thing is that they making shopping by PDF comparison quite easy.
http://incredulist.blogspot.com/2012/10/high-side-switching.html
The local post office here had me do something very odd. They made me go around the counter and go to the back of the general post office to pick up the package that was obviously opened for inspection. I got the impression that they wanted me on the postal office's video cameras in case I was making a bomb or something.
Just another odd misadventure in Asia.
I have ordered from them from time time I would say that if you have PayPal account I would use it with them just in case you do not get your order which almost happen to me once
I have bought there 5 volt power boards and they are very well made and easy to use
@sam_sam_sam, Paypal sounds like a good idea. I can stock up on components I use a lot of.
