Plastic Sheet recommendation
NWCCTV
I have decided to change the base of my robot project from aluminum to plastic. I have found a local supplier that sells 1/4" sheets cut to order. Which would be better for strength and durability plus not chip when cutting or drilling, ABS or PVC?
I am curious. Why the sudden desire to change? However, if you are determined to change, please consider this. For several years, I have been planning a special purpose robot inside the old noggin. Additionally, I have drawn up various plans that utilize stock aluminum materials. In all instances, the weight of the chassis and batteries have caused me to scrap these plans.
Although I have not spent much time thinking about the design in the last couple of years, I did have sort of an epiphany concerning the base platform, upon which all things will be built. Instead of building the base from stock aluminum materials, which results in some serious weight, machining, and other time and finance consuming issues, I have decided to use a premade base. And for this premade base, I will be utilizing some type of aluminum baking sheet, such as a cookie sheet. The cookie sheet is light weight and strong. Of course, the cookie sheet is made from some fairly thin material, but the sides make it very rigid.
Whatever material you decide to use, metal or plastic, consider using a premade form that is lightweight and has sides to increase rigidity.
Bruce
I also like to avoid PVC when I can. PVC is ~57% chlorine by weight and starts making HCl if heated much over 70C. It also requires lots plasticizers to be molded/extruded as it's melting point when pure is 83C.
Lawson
Plastic has been my choice for several reasons... 'tis lightweight, easy to work with and *cheap*! I go to a local distributor/fabricator (Tap Plastics) and rummage their cut-off bin where I can almost always find something very close to the size I need for less than $2 per pound. Once in a while, they'll just give me a piece or two because I shop there so much.
I can get PVC, ABS, Styrene, Acetal, Delrin and Nylon. It comes in white, black, red, green, blue, mirrored, transparent, translucent and "crinkly". :-)
The pile in the picture cost me about 15 bucks.
Amanda
If the only choices are ABS and PVC I would choose PVC for its light weight and easy workability. If other materials are possible I would choose cast acrylic because it lasers really well and is quite durable. I would choose aircraft ply because it is easy to work with and very strong. MDF is also easy to work with and quite strong, it is what I made my Mecanum robot out of.
-- Gordon
Edit:: So i just returned from a couple different plastic distributors. It some times amazes me as to how generous some people are when you tell them what you are doing. I went to Calsak Plastics in Kent, WA. and the lady there gave me a piece of Makrolon AR 14" x 36". Then, I went to Interstate Plastics in Kent, WA. I picked up a sheet of PVC14" x 30" and a piece of ABS 18" x 21", both pieces for $5.00. I think I will end up using the Makrolon because of its strength and the fact that it is clear will make a really cool looking base for my bot!!!! I also have enough material now to be able to build project boxes to enclose my electronics in!!!! What a deal!
