Cell Phone Camera where to?
Does anyone by chance know where I could find a company that sells the cameras that are installed in cell phones? I have an application idea and one of them would be perfect. I have thought of hacking a cell phone but I am worried about not knowing power consumption, etc.
SparkFun sells a couple of different little cameras I believe are also cell phone cameras but I think getting an image from one can be tricky.
Kye did the CMUcam4 but Joe Grand did the rangefinder.
They don't use the same camera. The CMUcam4 camera has a little ribbon cable while the rangefinder camera uses a ball grid on the bottom.
While the camera in the rangefinder is available to purchase in small quantities, I don't think there's a source for the CMUcam4's camera where one could only buy a couple (at least this was the case the last time I checked).
Joe has given some insight on how to hack the rangefinder camera in a couple of his threads. There's also some discussion about using the rangefinder as a camera here.
I might just have to do that. I took a look at the CMOS ones at Sparfun. The Datasheets look very similar to these same layouts and I may be able to get one to work. THink I will order about 5 of them.
Edit: I was going to buy 5 but minimum order is $10.00 so I bought 6. I am sure once I get them I will have some questions for the brainiacs in the forum!!!!!
http://www.sparkfun.com/datasheets/Sensors/Imaging/TCM8240MD_E150405_REV13.pdf
The CMUcam4 has a cell phone camera on it that can likely do what you want. The propeller chip's processing powers are not infinite but it can get stuff done. I can get you started with code to talk to the camera if you would like and how to change the firmware.
I do not recommend starting from scratch with a camera module. It is an unpleasant amount of work...
Now you tell me!!!! I already ordered 6 of them. Blame erco!!!! Is the CMUcam as small as the cell phone cams? they are only about 1/4' square and would be perfect for what I am trying to accomplish.
Edit: BTW, the project I am working on does not involve a prop or stamp. I will need to provide power directly to the camera and get video output directly from it. Is this possible or are there other HW requirements to accomplish this?
NOW you tell us! http://www.ebay.com/itm/Mini-Wired-SPY-Video-CCTV-Security-Color-Camera-NTSC-/261056826317?pt=US_Surveillance_Gadgets&hash=item3cc8330bcd
http://www.ebay.com/itm/New-Mini-Wireless-Nanny-Micro-Camera-Receiver-Full-Kit-/290780378303?forcev4exp=true&forceRpt=true
OK, I'll bite. What does HW mean to you? Hard Work?
For me, it's Hot Wheels.
Is there a source for the cameras in small quantities?
@NWCCTV,
I did link to a small camera available at Digi-Key. It's pretty small and used in the range finder.
If so, you could look on ebay for "reversing cameras" for cars/trucks.
@ NWCCTV - Oh you need video output... the CMUcam4 will not be able to give you that. Sorry,
You stated no prop/stamp - does that mean you need composite as the final output at the viewing point? If so, what distance away from the camera sensor does that composite output need to be? There are ways of transmitting high speed data over a few metres, eg LVDS, or CAT5 techniques, that *might* help you achieve what you want to do. But without nailing down some constraints we'll still be clutching
cheers
tubular
I was looking to use this exact camera module as it is indeed tiny and complete. I have requested the datasheet several times, not even to be offered a reply that said GO AWAY.
http://www.ovt.com/support/datasheet.php
I'm assuming since getting a datasheet requires an NDA is also the reason I cannot find the sheet anywhere on the internet... I found one on a Japanese site, but it was less than helpful.
To NWCCTV, I'm not sure your resolution requirements, however can you use a fiber optic pipe to the camera? Harbor Freight (I think) offered a snake camera, but it also offered relatively inexpensive extensions to that camera you could use for a remote camera. I've done a fair bit of research into this. I don't recall any readily available analog out cameras this tiny.
Some are very small.
They cost a lot more than the camera modules mentioned in this thread though.
Yea, I actually resell some of SC's product line. Even at discount pricing they are too high for what I need to do.
http://wenku.baidu.com/view/f9b8cf030740be1e650e9abe.html
http://wenku.baidu.com/view/2664fd19964bcf84b9d57b2f.html
This one is pretty small
