A Question About XBee And FCC Regulations
idbruce
Hello Everyone
I have a question about XBee and FCC regulations.
If I plug an XBee into the Propeller BOE and I attempt to sell the combination as a single product, does this product have to be approved by the FCC?
Digi International Inc. says their XBee modules are FCC certified, but referring to other RF modules, such as the 433 MHz RF Transceiver, which is sold by Parallax, there is a disclaimer on the bottom of the datasheet, which states:
FCC Notice and Liability Disclaimer
These modules (boards) are not FCC approved. They are designed to comply with FCC Part 15 Rules and Regulations. They are not in a finished product form. They are strictly intended for experimental purposes only. If you wish to use these modules in an actual product (a non-experimental capacity), the module must first be designed into the product then the whole product must be approved by the FCC.
Parallax, Inc. is not responsible for special, incidental, or consequential damages resulting from any breach of warranty, or under any legal theory, including lost profits, downtime, goodwill, damage to or replacement of equipment or property, and any costs of recovering, reprogramming, or reproducing any data stored in or used with Parallax products.
I am just curious.
Bruce
I am just curious.
Bruce
http://www.fcc.gov/encyclopedia/rules-regulations-title-47
I'm sure you'll find it fascinating reading.
Thanks for your input. I did not realize that the microcontroller end would need to be certified. A real eye opener there.
Yea, I was already glancing at FCC 15 and it looks pretty complicated to comprehend, and appears more complicated than patent law, however I assume that once it is actually studied, it would become quite clear.
Thanks Phil
Bruce
