Question about no Propeller Chip found
RDL2004
Will the Propeller fail to be detected if the eeprom is bad/missing?
I just wired up a board to use the Propeller chip that I got in the "Mystery Bag". I had checked all the voltages and checked for shorts and everything looked good. I then plugged in the Prop and the eeprom but somehow when doing that one of the LM317 resistors broke and both chips saw 6+ volts. I fixed the problem and replaced the Propeller but I don't have another eeprom. The Propeller Tool still doesn't detect a Prop. I just need to know if the eeprom could be the problem or if I need to dig deeper. Also, I checked my Prop Plug with another board and it's working fine. Thanks for any help.
I pulled the second chip out of my board and wired it up on a breadboard and it's no go. DOA apparently, or maybe my board killed it, though I still can't find anything wrong with it. Maybe next Mouser order I'll buy a few more chips, but test them on a breadboard first.
Got a picture?
Edit: oops, now I see what you mean.
What about to add some decoupling's capacitors around Propeller --- If You will not burn PLL in it?
Yes, this is a very good idea. Fortunately I had already done it, it was simply not visible because they were hiding under the chip
In this photo you can see the decoupling capacitors. You can also see the board as it was fixed. The socket at pins 39 and 40 was damaged beyond repair, so I had to transplant a section. Luckily, at this point only the corner and center section pins of the socket had been soldered down. This was just a sort of prototype board and there were a number of mistakes made while building it and there are several things that could be improved, I'll probably make an new version next week. I expect it will turn out much better.
as the DIP40-socket got damaged - maybe I'm quoting something you know very well - just in case not
desoldering is much easier with a desoldering vacuum pump.
http://www.amazon.com/Desoldering-Vacuum-Solder-Sucker-Removal/dp/B003FHYL7I
For desoldering as long as the copper-dot is hot the glue that sticks the copper to the PCB is melted.
As long as the glue is melted you shouldn't apply any mechanical forces to the copper-dot. Not by your soldering iron
not by a wire.
The desoldering vaccum pump sucks off the melted solder. With this you desolder pin for pin.
After that all the pins is free and you can pull the socket out of the pcb
just as like on a virgin PCB with nothing soldered yet.
Take a look into this thread where I posted two pictures of a DIY-board I made to see additional things
that I put on the board to get overcurrentprotection.
http://forums.parallax.com/showthread.php?143052-Low-Cost-DIY-Propeller-Board-with-overcurrentprotection
best regards
Stefan
