Ping))) sesor problems — Parallax Forums
EleutherEleuther Posts: 20
edited 2012-11-03 20:22 in Accessories
Hi everyone I'm only 14 and I need help with my Boe- Bot. I recently got the Ping sensor and servo mounting bracket. I have been looking for the programs to calibrate it such as Ping))) Dar I don't think that is the real name of it but if anyone could help me find it and maybe post a good program that allows my bot to rome with the sensor that would be great, thank you
  • EleutherEleuther Posts: 20
    edited 2012-10-09 19:44
    ok I found the programs and now I cant get it to use the program GoToNearestObject correctly. It will scan 180 degrees with kind of a stutter and then it doas a little turn to the right very slowly and then moves forward a tiny bit. Please help.
    edited 2012-10-09 19:53
    Hey, Eleuther, welcome to the forums. Have you worked through the BoeBot Book? There's lots of code in the book. Also, lots of programs (including 'roaming with ping') available at http://www.parallax.com/tabid/768/ProductID/92/Default.aspx
    Post your code, post a photo of your wiring, and make a Youtube video if possible. Fresh batteries are always important in a robot.
    Let us know how you make out, you're our most enthusiastic new roboticist!
    edited 2012-10-10 06:40
    Thanks that helped alot part of it was the battery it runs smother now and it executes the programs correctly. now I'm having problems with the roaming program I had to change the CON values a bit so I could get a 180 degrees without the servo maxing out her is the program I'm using and when I run it my bot never goes forward so I looked at the program and non of the tasks said to go forward I might just be missing something.
    ' File...... RoamingWithPING.bs2
    ' Purpose... Roam And Scan Using PING))) Mounting Bracket
    ' Author.... Parallax, Inc.
    ' E-mail.... support@parallax.com
    ' Started...
    ' Updated... 12-21-2005
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    [ Program Description ]
    ' This programs demonstrates roaming with the Parallax PING))) Mounting
    ' Bracket, which allows you to pan-scan with your Parallax PING))) sensor.
    ' This program assumes you have already set your BOE-Bot up for roaming
    ' with IR sensors. You must also have the PING))) Mounting bracket
    ' installed as per the instructions, with the servo connected to P14 and
    ' the PING))) sensor connected to P15.
    ' Due to the way the PING))) bracket mounts you may have to trim your IR
    ' detectors down so that they don't stick up in the way of the moving
    ' PING))) bracket as it rotates. It's best to angle them off at 45
    ' degree angles so that the BOE-Bot doesn't run into anything while
    ' moving along a wall at a narrow angle.
    ' The BOE-Bot will now roam around and when it senses an object, it will
    ' scan within a 180 degree field of view for the clearest path, which it
    ' will then navigate scanning for an object again. The IR Sensors prevent
    ' hitting a wall when coming at it from a narrow angle where the PING)))
    ' might have trouble seeing it due to the lack of reflection of sound.
    ' Calibration is important to this code working properly. If you do not
    ' have the correct values for your servos then you may get strange results
    ' from your BOE-Bot. The necessary calibration information is listed in
    ' each section of the code where it is required.
    [ Revision History ]
    ' This code is basically a modified version of the Roaming With IR code
    ' from the Robotics With The BOE-Bot Manual, written by Andy Lindsay.
    ' Much of the original code was left untouched so you can see how it was
    ' altered.
    [ I/O Definitions ]
    Piezo PIN 4 ' Piezo Speaker
    RightServo PIN 12 ' Right Servo
    LeftServo PIN 13 ' Left Servo
    PingServo PIN 14 ' PING))) Servo
    Ping PIN 15 ' PING))) Sensor
    [ Variables ]
    irDetectLeft VAR Bit ' Variable For Left IR Input
    irDetectRight VAR Bit ' Variable For Right IR Input
    pulseCount VAR Byte ' Used For Measuring Turns
    distance VAR Word ' Current Distance Of Object
    oldDistance VAR Word ' Old Distance Value
    counter VAR Word ' PING))) Cycle Counter
    task VAR Nib ' Current Task
    [ Initialization ]
    FREQOUT Piezo, 2000, 3000 ' Signal Program Start/Reset
    [ Program Code ]
    Main:
    DO
    FREQOUT 8, 1, 38500 ' Emit 38.5 kHz IR To Left
    irDetectLeft = IN9 ' Store IR Detection Values
    FREQOUT 2, 1, 38500 ' Emit 38.5 kHz IR To Right
    irDetectRight = IN0 ' Store IR Detection Values
    IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
    GOSUB Ping_Around ' Object Detected via IR Forward
    ELSEIF (irDetectLeft = 0) THEN
    GOSUB Ping_Around ' Object Detected via IR Left
    ELSEIF (irDetectRight = 0) THEN
    GOSUB Ping_Around ' Object Detected via IR Right
    ENDIF
    counter = counter + 1 ' Increment Passive Counter
    IF counter > 10 THEN ' Wait For 10 Servo Pulses
    GOSUB Ping_Out ' Activate PING)))
    ENDIF
    IF (distance > 30) THEN ' Is Object Farther Than 30 cm?
    GOSUB Forward_Pulse ' If Yes Go Forward
    ELSE
    GOSUB Ping_Around ' Otherwise Scan For Clear Path
    ENDIF
    LOOP
    [ Subroutines ]
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE FORWARD *
    ' * WHILE THE PING))) IS FACING FORWARD. *
    Forward_Pulse: ' Send A Single Forward Pulse
    PULSOUT PingServo, 750 ' Ping Servo Forward Pulse Value
    PULSOUT LeftServo, 850 ' Left Servo Forward Pulse Value
    PULSOUT RightServo, 650 ' Right Servo Forward Pulse Value
    PAUSE 20 ' Refresh Delay
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN LEFT 90 *
    ' * DEGREES. USE THE SAME VALUE AS ABOVE FOR THE PING))) BRACKET SERVO. *
    Turn_Left: ' Left Turn, About 45 Degrees
    FOR pulseCount = 0 TO 7 ' Number Of Pulses To Turn
    PULSOUT LeftServo, 650 ' Left Servo Left Pulse Value
    PULSOUT RightServo, 650 ' Right Servo Left Pulse Value
    NEXT
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN RIGHT 90 *
    Turn_Right: ' Right Turn, About 45 Degrees
    PULSOUT LeftServo, 850 ' Left Servo Right Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Right Pulse Value
    NEXT
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE BACKWARD *
    Back_Up: ' Back Up
    FOR pulseCount = 0 TO 40 ' Number Of Pulses To Backup
    PULSOUT LeftServo, 650 ' Left Servo Backup Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Backup Pulse Value
    NEXT
    RETURN
    Ping_Out: ' PING)))
    counter = 0 ' Reset Passive Delay Counter
    LOW Ping ' Force PING))) Line Low
    PULSOUT Ping, 5 ' Activate PING))) Pulse
    PULSIN Ping, 1, distance ' Receive Return Pulse
    distance = distance ** 2257 ' Calculate Distance
    RETURN
    Ping_Around: ' Start 180 Degree Pan-Scan
    oldDistance = 30 ' Current Old Distance Values
    task = 0 ' Current Task Priority
    ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) *
    ' * TURN 90 DEGREES LEFT. *
    FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin
    PULSOUT PingServo, 1085 ' Ping Servo 90 Left Pulse Value
    PULSIN Ping, 1, distance ' Receive Distance Value
    NEXT
    distance = distance ** 2257 ' Calculate Distance In cm
    IF distance > oldDistance THEN ' Is distance > Last Clear Path
    oldDistance = distance ' Update oldDistance Value
    task = 1
    ENDIF
    ' * TURN 45 DEGREES LEFT. *
    PULSOUT PingServo, 850 ' Ping Servo 45 Left Pulse Value
    NEXT
    task = 2
    ENDIF
    ' * TURN 45 DEGREES RIGHT. *
    PULSOUT PingServo, 400 ' Ping Servo 45 Right Pulse Value
    NEXT
    task = 3
    ENDIF
    ' * TURN 90 DEGREES RIGHT. *
    PULSOUT PingServo, 225 ' Ping Servo 90 Right Pulse Value
    NEXT
    task = 4
    ENDIF
    ON task GOSUB Task0, Task1, Task2, Task3, Task4
    distance = 50 ' Prevent Scan From Looping
    RETURN
    Task0: ' Forward Was Clearest Path
    GOSUB Turn_Right ' This Could Mean Narrow Path
    GOSUB Turn_Right ' So We'll Turn Around
    GOSUB Turn_Right ' You Can Change The Behavior
    GOSUB Turn_Right ' Of Any Of The Tasks
    RETURN
    Task1: ' 90 Degrees Left Was Clearest
    GOSUB Turn_Left
    GOSUB Turn_Left
    RETURN
    Task2: ' 45 Degrees Left Was Clearest
    GOSUB Turn_Left
    RETURN
    Task3: ' 45 Degrees Right Was Clearest
    GOSUB Turn_Right
    RETURN
    Task4: ' 90 Degrees Right Was Clearest
    GOSUB Turn_Right
    GOSUB Turn_Right
    RETURN
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-10-31 16:41
    The value "850" on one servo and "650" on the other will make the boebot go forward and switching the values will make it go in reverse. Does that make sense to you? Try placing objects to the left and right sides of the bot to see how it reacts. And welcome to the forums.
  • robotboyrobotboy Posts: 30
    edited 2012-11-02 09:21
    I used this one
    ' -----[ I/O Definitions ]-------------------------------------------------
    ' -----[ Variables ]-------------------------------------------------------
    ' -----[ Initialization ]--------------------------------------------------
    ' -----[ Program Code ]----------------------------------------------------
    Main:
    DO
    ENDIF
    ELSE
    ENDIF
    LOOP
    ' -----[ Subroutines ]-----------------------------------------------------
    RETURN
    NEXT
    RETURN
    NEXT
    RETURN
    Back_Up: ' Back Up
    NEXT
    RETURN
    Ping_Out: ' PING)))
    RETURN
    NEXT
    task = 1
    ENDIF
    NEXT
    task = 2
    ENDIF
    NEXT
    task = 3
    ENDIF
    NEXT
    task = 4
    ENDIF
    RETURN
    RETURN
    GOSUB Turn_Left
    GOSUB Turn_Left
    RETURN
    GOSUB Turn_Left
    RETURN
    GOSUB Turn_Right
    RETURN
    GOSUB Turn_Right
    GOSUB Turn_Right
    RETURN
    edited 2012-11-02 14:28
    Hi robotboy,
    I did a slight edit to your last post to include the "code" "/code" key-words, which help with reading long sections of code.
    davejames
    edited 2012-11-03 11:37
    Nice job, davejames! I see you are a moderator now. Well done!
    With great power comes great responsibility... SpiderMan's Uncle Ben's Rice, I think
    ...I understand Sir. I'm honored by the trust, and scared of the responsibility.
    Thanks man.
