Pillow Block/Motor Mount question
NWCCTV
I am in the process of grinding out and drilling my pillow blocks to go on my bot. I am curious if anyone thinks it would be a good idea to mount springs underneath the pillowblocks and motors to act as shock absorbers. I had previously thought of doing this just on the motors but figured it would be a moot point if the pillow blocks were not also supported like this. My motors weigh almost 1 pound each which is the reason I designed pillow blocks to set the axles in. The axles will be roughly 5 inches in length. Before you ask, no, I do not have drawings. I tend to design things in my head and put on paper after I figure out if it will work or not.
My $0.02 is that onboard electronics and batteries can use all the cushion they can get but excess slop in the drive train will wear it out faster.
Edit: Concept was to place springs underneath motors where they bolt to chassis thus acting similar to motor mounts in autos.
But that wasn't an option in this abuse case! http://autos.yahoo.com/blogs/motoramic/camaro-owner-records-mechanics-abusing-car-scheming-damages-152707580.html
If you had a chain drive you could put suspension on the pillows and motor independently and the chain will take care of the rest. I haven't done any direct drive using axles though.
No, Motor, Shaft, Bearing inside pillow block, wheel.
I understand this but it is not the way I designed it. I want as few moving parts as possible and do not want to use chain becuase they tend to rust. I am not looking for new ideas. I just want to know if using springs would be a good idea or not to support the motor/axle/wheel assembly because of the weight of the motors.
What it needs are some cardan joints... Then you can bolt the motors down solid and just put springs on the pillows
Haha, I hear you. Mine was a very hasty job to say the least and still took too long. I'd still go with soft tires, a padded battery box, and rubber mounted electronics over suspension. Then again I don't have the means to do anything else lol...
No, it's all steel. I completely stripped the wheel chair, cleaned and then painted all the parts. It used to be all black. I like lighter colors so that I can actually see what I'm doing.
It's the robot I brought to UPEW 2010. I have just last week ordered a second 55Ah battery so that I can run it off 24V. It only took two and a half years... maybe by next UPEW Expo it will be fully functional.
WOW. That is impressive. I was thinking steel but then thought that would be too heavy!!!!! It is a nice job though.
I guess legs would be a good addition in that case!!!
