Ideas for a diffuser for an LED
I have a blue super bright LED which I've been using with my line scan camera. The light spot it produces is too focused and unevenly illuminates the subject. So I made a diffuser out of tissue which improved things, but there's still a bright spot from uneven illumination. Some scheme to better diffuse the light is in order, but I am not sure what.
Any ideas for a fool proof diffuser? Either that or I build a different LED using several wide angle LED's in a row.
Unless you're doing RGB color vision, you're not doing yourself any favors by using blue, since that's the color the TSL1401 is least sensitive to. I would suggest red instead.
I would also suggest using so-called "superflux" LEDs in a P4 (aka "Piranha") housing. These typically have a very wide-agnle spread and even light distribution, which is ideal for the TSL1401-DB.
If you feel you must use a diffuser, request samples of holographic diffusers from these guys:
They will give you the most even illumination possible.
Perhaps you can somehow grind the top of your LED flat?
I bought a 100 pak of super bright, white, flat-top LEDs on ebay for 5 USD
and the light spreads out almost like it is from a point source.
http://www.radioshack.com/product/index.jsp?productId=3097459&filterName=Type&filterValue=Specialty#
I also searched with Google and apparently grinding the top of an LED flat is a common way to get a more defuse output. I might try that at some point with the existing LED.
Sand the dome off the LED and leave the flat suface rough.
Edit: Martin, I hadn't seen you last post. I think the first time I read about sanding the dome off a LED was in an article by JonnyMac in Nuts & Volts.
Here's the new LED lamp plugged into the TSL1401.
I use a 2N2222 to provide current to the LED since the Propeller doesn't have the current output for this sort of LED.
Top cutaway view Face of D-Sub mate connector ┌──────────────┐ ┌┴──────────────┴┐ │ │ ┌─────┴────────────────┴─────┐ │   ─── Stand offs │ ────────────────────── ─── White Copy Paper (Sheet or two, depending on the brightness you want) │  LED's  │ │  ‣‣‣‣‣‣‣‣‣‣‣‣  │ │  ‣‣‣‣‣‣‣‣‣‣‣‣  │ │  ─── PCB │   │ │   │ └────────────────────────────┘It ended up working quite well, and I have made a couple of these using super high brightness Blue LED's with standard dome top. Just put in a row of the LED's and the paper does the rest.
MUCH easier and cheaper than the "Fiber Optic" idea my boss had
