I can't believe I found a HW BUG in the propeller
Now that I have your attention
I found a really strange behavior when using MAX/S and MIN/S with FRQA. Attached is a demo program you can compile and run and the resulting waveforms I sampled with a logic analyzer
MAXS_MINS PASM bug.spin
To summarize the problem:
If you use max/s or min/s directly with FRQA in the dest field, something happens with the counter like it seems to set the counter to the source field even though you read FRQA correctly, it's an internal HW problem, your program still believes it has FRQA on the counter BUT in reality your pin is at the max (or min) limit you specified.
As you can see in the program you can easily circumvent the problem by reading and storing again the value (or even better read, maxs and write back FRQA on a working register)
Here you see what happens to the output waveform on a MAXS FRQA, FRQ_max
Immediately after just waiting a second this happens on ADD FRQA, #0 (just restores the right value). As you can see the correct value is stored on FRQA but now it get the correct value on the output pin.
I would recomend studying in detail this behavior and modifying the Propeller manual to alert users on this behavior.
Regards
Alex
Regards
Alex
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB main cognew(@entry, 0) DAT org 0 entry mov time,one_second add time,cnt waitcnt time,one_second 'Wait 1 sec before starting. mov dira,#1 'Set bit 0 to output. mov ctra,ctra0 'Set ctra to NCO; output on P0. mov frqa,fmin waitcnt time,one_second 'Pause 1 sec. maxs frqa,fmax waitcnt time,one_second 'Pause 1 sec. add frqa,#0 'Set HW output correctly again. jmp #$ one_second long 80_000_000 'cnt cycles for 1 sec. ctra0 long %00100<<26 'NCO to generate step pulses. fmax long 53000 'Working parameter: fmax for job. fmin long 5300 'Working parameter: fmin for job. time res 1I have to say that something odd is happening, and it probalby has to do with frqa's shadow register. But nothing has ever been documented that frqa cannot be used with impunity as the destination of a read-modify-write instruction. It should behave normally under these circumstances.
Now, the following program works as you would expect:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB main cognew(@entry, 0) DAT org 0 entry mov time,one_second add time,cnt waitcnt time,one_second 'Wait 1 sec before starting. mov dira,#1 'Set bit 0 to output. mov ctra,ctra0 'Set ctra to NCO; output on P0. mov acc,fmin mov frqa,acc waitcnt time,one_second 'Pause 1 sec. maxs acc,fmax mov frqa,acc waitcnt time,one_second 'Pause 1 sec. add acc,#0 mov frqa,acc 'Set HW output correctly again. jmp #$ one_second long 80_000_000 'cnt cycles for 1 sec. ctra0 long %00100<<26 'NCO to generate step pulses. fmax long 53000 'Working parameter: fmax for job. fmin long 5300 'Working parameter: fmin for job. time res 1 acc res 1Dunno what to think. It definitely seems to be an anomaly.
Hopefully Kuroneko has awakened and tuned in. He's the de facto custodian of weird Propeller behavior. Maybe he can shed some light.
Quick tests show the same behaviour for other h/w backed registers, e.g. max phsa, one_second leaves the shadow intact (small enough) but the counter register is preset with 80M. This may come in handy, who knows?
PUB null cognew(@entry, 0) DAT org 0 entry max dira, mask max frqa, frqa_ max ctra, ctra_ ' video PLL, clock exposed (16) max frqb, #255 max ctrb, ctrb_ ' NCO (17) max vcfg, vcfg_ max vscl, vscl_ ' video (18..23) mov temp, dira or temp, frqa or temp, frqb or temp, ctra or temp, ctrb or temp, vcfg or temp, vscl wz if_nz hubop $, #%10000_000 ' reset of non-zero waitpeq $, #%%210 mask long $00FF0000 frqa_ long $10000000 ' 5MHz ctra_ long %0_00010_000 << 23 | 16 ctrb_ long %0_00100_000 << 23 | 17 vcfg_ long %0_01_1_00_000 << 23 | 2 << 9 | $FC vscl_ long 255 << 12 | 4095 temp res 1 fit DATThis is effective for all SPRs (actually I haven't bothered checking the r/o section and vscl). The former is ... r/o and the latter not useful for code. Which means that under certain circumstances 15 SPRs can be used for code/data while their connected h/w still does its job.Its only a BUG if it contradicts the stated requirements. If there is no description, it is simply NOT DEFINED or in this case NOT YET DEFINED.
So, to clarify, (I only check that the docs line up, I don't necessarily understand all the details), this is NOT a bug, since nothing defines what FREQA+MAX does concerning the the shadow register(?) [Please help me state the issue clearly, I just got up]
And the observed behavior is....something to the affect that it does its job while the cog can do other stuff? [Ok, I'll get some coffee...]
My aim here is to turn it from an undocumented anomaly to a documented behavior. Then somebody else can show us how to take advantage of this function and/or how to avoid put falls of its presence.
compared with any other MCUs the propeller-chip to me is still No 1 even in category "free of bugs"
So I would like to ask Chip Gracey directly. Chip are you still reading headlines of the threads?
If you are busy with re-re-checking the circuitry of the propeller-2-Chip please stop checking for a moment read this thread
and then check the Prop-Chip 2 if the P2-chip has the same feature.
best regards
Stefan
10) Not using pest control
9) Being unnecessarily exposed to risks
8) Making solutions overly complex
7) Faults in steps or logic
6) Not verifying function
5) Expecting something to "just work"
4) Not meeting natural expectations
3) Not communicating how something should work
2) Failure of user to find/comprehend published material
1) Not getting everyone's approval on how something should work in the first place
IT IS COMPLETELY IRRELEVANT whats in the engineer's head or what the "intent" was if it is not written down and communicated to us the folks that need the information. The only thing that matters is what does it CLAIM TO DO, and what does it ACTUALLY DO. Claims of functionality and actual functionality are the only things we can check, and confirm or deny. All else is undefined. These claims are recorded in the documentation. Documented claims are the only thing that exist, and are the only thing we can measure against. Any "claim" that is not documented cannot be claimed to exist, and for all practical purposes does not exist.
Does the document state specifically state the behavior for this specific function is other than observed? Is this function so obscure that it is undefined and that is OK? We cannot expect anyone to see the future and guess every possible weird thing that may ever come to pass. Some things are just left "undefined" until such a lime as they raise their head and demand attention. This may be one of those, since nobody noticed it before in all these years.
If it is inconsistent with the other special register functions, can it be stated in the docs that this one reads the input bus instead of the output bus for setting this bit? (or whatever its doing, you pretty much lost me at FRQA). If the documentation can be made to describe this as the intended (or accepted) behavior, it cannot be considered a bug. It may be weird, but if its in the docs and we know about it, we are not set up to get burned.
Even it this contradicts the stated behavior of the other special registers, the docs can be made to state that this function has an exception, it can no longer be called a bug.
This is a kind of cool discussion. I want to see if we establish the intended function, the actual function, and accurate documentation of the analysis.
- FRQA set the output frequency of the counter in the sample program above (NCO=numerically controlled oscillator)
- MAX/s or MIN/s limit the maximum or minimum value of a register (any register that can be used in read/modify/write instructions). These instructions do on FRQA whats supposed to happen.
- However after these instructions FRQA does NOT reflect the output frequency of the counter. FRQA has the value that you expect, it's the output of the counter that is wrong.
Absolutely, that's what I stated when opening this thread. Let's get the manual to reflect this as a warning so others don't stumble on this behavior. Until now it's a BUG, when we change the manual you'll be warned and it's no longer a bug.
I would suggest to modify both the special registers section and the MAX/MIN instructions.
Alex
I assume this will not be the case with the Prop II, in part, since the SFRs are hidden from R/M/W instructions; correct?
Is it a "feature" that will be carried to the Prop II or is it a "bug" that will be fixed in Prop II?
Given the time in the market with no reports on this it's obviously not a big issue, but will someone at Parallax clarify this in the manual so the next lunatic that tries this be warned?
Thanks in advance.
Alex
I created a task in our issue tracker to add the information in the next revision of the Propeller Manual.
— David Carrier
Parallax Inc.
Thanks a lot David! I appreciate that.
As we are accustomed around here, Parallax stands out in support for it's users, great work!
I'm glad I chose the Propeller for my projects.
Alex
In this case its "just the documented way it works" in the prop 1 (once the doc is updated).
Prop 2 will likely be determined by observing "late arriving", or not, on that hardware.
This is kind of cool that an anomaly can go undetected so long, then be detected and verified by the community, and acknowledged and addressed by the company so quickly. Whats that, 5 days turn around? Brilliant!
Since no one has encountered this before, "The solution is to not use MINS/MAXS/MIN/MAX/CMPSUB on I/O registers. " seems an acceptable resolution.
"Find a way to exploit the newly-documented behavior," is even better!
Would it even be possible to make such a change (if it is needed) without having to restart the whole routing process (weeks!) and pushing back the timeline even further?
The Prop II doesn't use write cancellation. It just outputs the correct result, in any case. So, this won't be an issue on Prop II. There could be other issues, though.
When I was looking through the Prop I hardware-description code today, I was amazed at how small it was compared to the Prop II code. It's about 1/9 the size, in a more verbose language, making it probably 1/13th the complexity of Prop II. I've written many test programs for the Prop II that I run and verify at each hardware-description iteration, so I'm planning for the best outcome. My main fear is that some catastrophic bug might exist because of some mistake made ABOVE the Verilog description, relating to our own circuitry. Hopefully, the chip will just work the first time we build it.
{...crosses finger and toes, lights candles, faces Rocklin and chants calming mantra "hmmmm, lots of speed, lots of pins, hmmmmm"...)
Three times a day?
Yes, best of luck to Parallax.
