prop to prop
I am working on a project where two props will talk back and forth. RX->TX...TX->RX. Each prop has a separate power source. Therefore, I have two power sources. Do I need to connect the gnds together...or is it okay to just connect the RX and TX lines?
I second the motion.
Wouldn't it matter based on how the devices are powered? If the devices are both plugged in to AC outlets, then connecting the ground wires would create a ground loop in the system. This would create noise, and possibly spurious readings.
Reference: http://siber-sonic.com/electronics/GLoopwhatis.html
Perhaps a more detailed explanation of your actual setup environment is necessary for us to give an appropriate response.
Well the point is digital logic has a noise-margin, often around 1V - any noise below that level is irrelevant. For analog circuitry (read audio amplifier) 1mV of noise could be a show-stopper. So whether you need to worry about ground loops depends on the amount of noise you can tolerate and the rate of magnetic flux change through the loop and the resistance round the loop.
Large loops such as mains-completely loops are usually a problem for everything (mainly because of switching or lightning transients on the mains wiring coupling to the earth wire). Thus for digital electronic devices is it normally the case that circuit ground is isolated from mains earth. (Or lightly coupled via RFC and resistor).
Where this cannot be achieved for whatever reason opto-isolated, pulse-transformer-isolated or differential logic signalling is employed (RS485, ethernet, MIDI etc)
