compiling propgcc on osx (10.4, no 64-bit capabilities)
Since the only binaries for propgcc are posted for 64-bit systems, I was going to attempt to compile my own version of propgcc. I did download the code when it was in alpha, but don't remember if I did anything with it or not.
So, fresh download today, and then started the rebuild.sh script.
(it was a strong temptation to build it all manually, since that's my nature, and instructions were provided, but I figured let the automatic process have it's chance first)
So, during the binutils process, it came up with this error.
Anyone here have a quick solution for this one? I've never had much luck fixing gcc compile errors when it's a big project like this one. automake and friends is beyond me. I like small projects, where I can modify the code directly when something happens.
I'm sure this one has a (relatively) simple solution, assuming of course, gcc 4.0.1 can actually do the compile. Any help would be appreciated.
gcc -DHAVE_CONFIG_H -I. -I../../../propgcc/binutils/ld -I. -I../../../propgcc/binutils/ld -I../bfd -I../../../propgcc/binutils/ld/../bfd -I../../../propgcc/binutils/ld/../include -g -O2 -DENABLE_PLUGINS -DLOCALEDIR="\"/opt/parallax/share/locale\"" -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Werror -g -O2 -MT ldlang.o -MD -MP -MF .deps/ldlang.Tpo -c -o ldlang.o ../../../propgcc/binutils/ld/ldlang.c cc1: warnings being treated as errors In file included from ../../../propgcc/binutils/ld/ldlang.c:43: ../../../propgcc/binutils/ld/../bfd/libbfd.h:2283: warning: declaration of 'link_info' shadows a global declaration ../../../propgcc/binutils/ld/ldmain.h:42: warning: shadowed declaration is here make[4]: *** [ldlang.o] Error 1Now, since I'm running 10.4 tiger, I don't exactly have the latest compilers, but I am using gcc 4.0.1.
Hi.
It's unclear at this point what the best path is. You may have hit a bug in the native gcc 4.0.1 compiler. Updating the native gcc compiler would be best if possible.
If one could turn off -Werror by using NO_WERROR in the makefiles, the compile might get further along, but another warning may appear later.
