trouble with xbee code
hello all,
I am having trouble with some code for an xbee. overview of project is i have two bs2's connected to xbees, I have one bs2/xbee with two pushbuttons the other with two different colored led's. I am trying to get it so one pushbutton will control one color and the other pushbotton the other color.
problem i am having:
regardless of what button is pushed the lights go on in a pattern. first the green, then the red. If i hit Pushbutton one 5 time it will go green, red, green......and so on. it i hit any combination of the two buttons it still repeats the pattern of green, red, green, red, green,...and so on
transmitting code
receiving code
transmitting code
' {$STAMP BS2}
' {$PBASIC 2.5}
'----------------[Initialize]---------------------------
PAUSE 5
SEROUT 2, 84, [22,12]
SEROUT 2, 84,50, [22,17, "Hello", 13, "Geno"]
PAUSE 1000
PAUSE 5
'---------------[Variables]-----------------------------
LR VAR Word
UD VAR Word
btn1wrk VAR Byte
btn2wrk VAR Byte
Led VAR Bit
Led1 VAR Bit
'---------------[Constants]-----------------------------
BUTTON btn1, 1, 0, 0, btn1Wrk,0, No_Press
BUTTON btn2, 1, 0, 0, btn2Wrk,0, No_Press
Btn1 PIN 6
Btn2 PIN 7
Tx PIN 14 ' XBee DIN
Rx PIN 15 ' XBee DOUT
stickUD CON 25
stickLD CON 25
'-------------------------[Main]---------------------------
Main:
HIGH 13
PAUSE 2
RCTIME 13, 1, UD
HIGH 12
PAUSE 2
RCTIME 12, 1, LR
DEBUG HOME, "UD =", DEC UD, CLREOL, CR,
"LR = ", DEC LR, CLREOL
IF UD > stickUD + 2 THEN GOSUB Forward
IF UD < stickUD - 2 THEN GOSUB Backwards
IF UD = stickUD THEN GOSUB Clear
IF LR > stickLD + 2 THEN GOSUB Right
IF LR < stickLD - 2 THEN GOSUB Left
IF LR = stickLD THEN GOSUB Clear
IF btn1 =1 THEN
DEBUG CR, "Button 1 pushed"
GOSUB Left_Turn
DEBUG CLS
ENDIF
IF btn2 = 1 THEN
DEBUG CR, "Button 2 pushed"
GOSUB Right_Turn
DEBUG CLS
ENDIF
No_Press:
GOTO main
GOTO main
'-------------------------[Sub Routine]-----------------------
Forward:
SEROUT 2,84, 20, [17, 128, "Forward"]
PAUSE 200
RETURN
Backwards:
SEROUT 2, 84, 20, [17, 128, "Backwards"]
PAUSE 200
RETURN
Right:
SEROUT 2, 84, 20, [17, 148, "Right"]
PAUSE 200
RETURN
Left:
SEROUT 2, 84, 20, [17,148, "left"]
PAUSE 200
RETURN
Clear:
SEROUT 2, 84, [12,17]
PAUSE 200
RETURN
Left_Turn:
IF Btn1 = 1 THEN SEROUT 2, 84, ["Left", 13, "Turn"]
SEROUT Tx, 84,[ DEC Led,CR]
PAUSE 500
IF Btn1 = 0 THEN SEROUT 2, 84, [12]
PAUSE 5
RETURN
Right_Turn:
IF btn2 = 1 THEN SEROUT 2, 84, ["Right", 13, "Turn"]
SEROUT Tx, 84, [DEC Led1,CR]
PAUSE 500
IF btn2 = 0 THEN SEROUT 2, 84, [12]
PAUSE 5
RETURN
receiving code
' Simple_Control_Remote.bs2
' Receives decimal value to control buzzer and LED
' {$STAMP BS2}
' {$PBASIC 2.5}
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T9600 CON 84
#CASE BS2SX, BS2P
T9600 CON 240
#CASE BS2PX
T9600 CON 396
#ENDSELECT
' ***************** Variables, Constants and Pins
Baud CON T9600 ' Set Baud rate
Led PIN 0
Led1 PIN 1
green VAR Byte
red VAR Byte
' ***************** Main Loop
DO
SERIN Rx, Baud, [DEC green] ' Wait for decimal and accept
HIGH LED ' Turn on LED
PAUSE 1000
LOW LED ' Turn off LED
SERIN Rx, Baud, [DEC red]
HIGH Led1
PAUSE 1000
LOW Led1
LOOP
this is one example. It was all i had to show because i didnt save any of the non working codes.
' *************************************************** ' Simple_Control_Remote.bs2 ' Receives decimal value to control buzzer and LED ' *************************************************** ' {$STAMP BS2} ' {$PBASIC 2.5} #SELECT $STAMP #CASE BS2, BS2E, BS2PE T9600 CON 84 #CASE BS2SX, BS2P T9600 CON 240 #CASE BS2PX T9600 CON 396 #ENDSELECT ' ***************** Variables, Constants and Pins Baud CON T9600 ' Set Baud rate Rx PIN 15 ' XBee DOUT Tx PIN 14 ' XBee DIN Led PIN 0 Led1 PIN 1 ' ***************** Main Loop DO SERIN Rx, 84, [DEC led] SERIN Rx, 84, [DEC led1] IF Led = 1 THEN HIGH LED ' Turn on LED PAUSE 1000 LOW LED ' Turn off LED ENDIF IF Led1 = 1 THEN HIGH Led1 PAUSE 1000 LOW Led1 ENDIF LOOPtransmit
Left_Turn: IF Btn1 = 1 THEN SEROUT 2, 84, ["Left", 13, "Turn"] SEROUT Tx, 84,[DEC 0,CR] PAUSE 500 IF Btn1 = 0 THEN SEROUT 2, 84, [12] PAUSE 5 RETURN Right_Turn: IF btn2 = 1 THEN SEROUT 2, 84, ["Right", 13, "Turn"] SEROUT Tx, 84, [DEC 1,CR] PAUSE 500 IF btn2 = 0 THEN SEROUT 2, 84, [12] PAUSE 5 RETURNreceive
