Humidty Sensor circuit question
Hi
The project circuit shown in: http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/27920-HS1101-v1.0.pdf
lists a 10 MOhm resistor in parrallel between vss and the pin 7
My question is the 10 M ohm resistor shown in diagram correct?
If so where can one be found?
Is there another way to wire this circuit and the humidty sensor?
There is no mention of a 10 M ohm resistor in the Parrallax online store.
