That's the relevant bit I was missing! I'm not in a position to test this at the moment, but this makes sense. Although even if I trigger the data line I don't see anything. In what you describe I can see why I get no clock, but I would have expected data to be shifted out. Sounds like this might be the same problem. The phsX register can't manipulate the expected bin because it just so happened that I pick a test value that ended in bit[0]=1. I guess that's better than having chosen it to end in 0 in which case I'd have had a really hard time finding it.
It just occurred to me that you could use the counter even for the slow code. neg phsb, #1 would raise the clock line and mov phsb, #0 lower it (NCO, pin := phsx[31]). This way outa wouldn't get in the way. The only thing to be aware of here is that the clock for fast mode is then delayed for one system clock (since phsb is left at -1). This may or may not be an issue. Just something to be aware off. HTH
Confirmed. Again, you could use a similar approach as the one outlined above (instead of muxc use rcr phsa, #1).
Just noticed that you preset phsb for the clock anyway so there would be no clock delay.
With Kuroneko's help I was able to get this sorted. As he pointed out, the complete code I posted above left some pins high when I exited my slow routines which meant the fast routines (and the counter in particular) couldn't lower the clock or output pins because the output state is the logical OR of all the different factions that have control over the state of a pin. By making sure my slow routines left both clock and data low on exit, I was able to get lonesock's code working. Thanks to all for the help, especially kuroneko.
Here are the working versions. A slow read/write, fast read, faster write:
{******************************** RW_BYTE ******************************************************
This command grabs reads the number of bytes to write from the HUB location byteCountPtr, then
writes (byte wise) the bytes beginning at bufferVal. Because it is SPI it also reads from the
WIFI module at the same time. The result is placed in the same slot of the buffer as the sent
value.
Z=1 when we enter. Z=1 when finished.
RW_BYTE
rdlong numBytes, byteCountPtr ' how many bytes are we supposed to write?
' mov temp, bufferPtr ' bufferPtr points to the HUB mailbox
' get a copy of that location for future use
rdlong hubAddress, bufferPtr ' read the addresss of the buffer; currently found in HUB mailbox
:byteLoop
mov inData, #0 ' init before filling
mov numBits, #8 ' init number of bits to read/write
rdbyte outData, hubAddress ' get local copy of data to write
shl outData, #24 ' shift lowest byte into MSB; bit[7]->bit[31]
:bitLoop
shl outData, #1 wc ' set C = outData[31] then shift
muxc outa, mosiMask ' put value of C onto MOSI
muxz outa, clkMask ' raise clock
test misoMask, ina wc ' C=ina[miso]
muxnz outa, clkMask ' lower clock
rcl inData, #1 ' shift C left into inByte
djnz numBits, #:bitLoop ' decrement loop
wrbyte inData, hubAddress ' write the data back to the buffer
muxnz outa, mosiMask ' make sure data line is low on exit
add hubAddress, #1 ' set pointer to next byte in buffer
djnz numBytes, #:byteLoop ' Decrement loop count.
RW_BYTE_ret ret
{******************************** R_BYTE ******************************************************
High speed read ONLY for SINGLE byte. This method clocks out $00 and reads the data
coming in on MISO. Clock is about 9.6Mhz. Writes the input data back to hub memory
address that was passed to this method. Using lonesock's method from FSRW.
R_BYTE
neg phsa, #1 ' DI high
mov inData, #0
' set up my clock, and start it
movi phsb, #%011_000000
movi frqb, #%001_000000
' keep reading in my value
rcl inData, #1
rcl inData, #1
rcl inData, #1
rcl inData, #1
rcl inData, #1
rcl inData, #1
rcl inData, #1
mov frqb, #0 ' stop the clock
rcl inData, #1
mov phsa, #0 'DI low
R_BYTE_ret ret
{******************************** W_FAST ******************************************************
This command reads the number of bytes to write from the HUB location byteCountPtr, then
writes (byte wise) the bytes beginning at bufferVal. This is a stripped down version of the RW_BYTE
code and does NOT capture a response. It's write ONLY. Also based on lonesock/rokicki's FSRW code
W_FAST
:byteLoop
mov phsa, outData ' start with the raw data byte
shl phsa, #24 ' get the MSb into position 31
'rev phsa, #0 ' do this instead of the above line for LSb first
movi phsb, #%000000000 ' set up my clock register
movi frqb, #%010000000 ' start my clock line ticking!
shl phsa, #1 ' move next bit into the PHSA[31] slot
mov frqb, #0 ' stop my clock
W_FAST_ret ret
Again, thanks for your help.
Peter
{******************************** RW_BYTE ****************************************************** This command grabs reads the number of bytes to write from the HUB location byteCountPtr, then writes (byte wise) the bytes beginning at bufferVal. Because it is SPI it also reads from the WIFI module at the same time. The result is placed in the same slot of the buffer as the sent value. Z=1 when we enter. Z=1 when finished. ***************************************************************************************************} RW_BYTE rdlong numBytes, byteCountPtr ' how many bytes are we supposed to write? ' mov temp, bufferPtr ' bufferPtr points to the HUB mailbox ' get a copy of that location for future use rdlong hubAddress, bufferPtr ' read the addresss of the buffer; currently found in HUB mailbox :byteLoop mov inData, #0 ' init before filling mov numBits, #8 ' init number of bits to read/write rdbyte outData, hubAddress ' get local copy of data to write shl outData, #24 ' shift lowest byte into MSB; bit[7]->bit[31] :bitLoop shl outData, #1 wc ' set C = outData[31] then shift muxc outa, mosiMask ' put value of C onto MOSI muxz outa, clkMask ' raise clock test misoMask, ina wc ' C=ina[miso] muxnz outa, clkMask ' lower clock rcl inData, #1 ' shift C left into inByte djnz numBits, #:bitLoop ' decrement loop wrbyte inData, hubAddress ' write the data back to the buffer muxnz outa, mosiMask ' make sure data line is low on exit add hubAddress, #1 ' set pointer to next byte in buffer djnz numBytes, #:byteLoop ' Decrement loop count. RW_BYTE_ret ret {******************************** R_BYTE ****************************************************** High speed read ONLY for SINGLE byte. This method clocks out $00 and reads the data coming in on MISO. Clock is about 9.6Mhz. Writes the input data back to hub memory address that was passed to this method. Using lonesock's method from FSRW. Z=1 when we enter. Z=1 when finished. ***************************************************************************************************} R_BYTE rdlong hubAddress, bufferPtr ' read the addresss of the buffer; currently found in HUB mailbox neg phsa, #1 ' DI high mov inData, #0 ' set up my clock, and start it movi phsb, #%011_000000 movi frqb, #%001_000000 ' keep reading in my value test misoMask, ina wc rcl inData, #1 test misoMask, ina wc rcl inData, #1 test misoMask, ina wc rcl inData, #1 test misoMask, ina wc rcl inData, #1 test misoMask, ina wc rcl inData, #1 test misoMask, ina wc rcl inData, #1 test misoMask, ina wc rcl inData, #1 test misoMask, ina wc mov frqb, #0 ' stop the clock rcl inData, #1 mov phsa, #0 'DI low wrbyte inData, hubAddress ' write the data back to the buffer R_BYTE_ret ret {******************************** W_FAST ****************************************************** This command reads the number of bytes to write from the HUB location byteCountPtr, then writes (byte wise) the bytes beginning at bufferVal. This is a stripped down version of the RW_BYTE code and does NOT capture a response. It's write ONLY. Also based on lonesock/rokicki's FSRW code Z=1 when we enter. Z=1 when finished. ***************************************************************************************************} W_FAST rdlong numBytes, byteCountPtr ' how many bytes are we supposed to write? rdlong hubAddress, bufferPtr ' read the addresss of the buffer; currently found in HUB mailbox :byteLoop rdbyte outData, hubAddress ' get local copy of data to write mov phsa, outData ' start with the raw data byte shl phsa, #24 ' get the MSb into position 31 'rev phsa, #0 ' do this instead of the above line for LSb first movi phsb, #%000000000 ' set up my clock register movi frqb, #%010000000 ' start my clock line ticking! shl phsa, #1 ' move next bit into the PHSA[31] slot shl phsa, #1 ' move next bit into the PHSA[31] slot shl phsa, #1 ' move next bit into the PHSA[31] slot shl phsa, #1 ' move next bit into the PHSA[31] slot shl phsa, #1 ' move next bit into the PHSA[31] slot shl phsa, #1 ' move next bit into the PHSA[31] slot shl phsa, #1 ' move next bit into the PHSA[31] slot mov frqb, #0 ' stop my clock add hubAddress, #1 ' set pointer to next byte in buffer djnz numBytes, #:byteLoop ' Decrement loop count. W_FAST_ret ret
