Debian testing.Syntax error after install
Hi there
Debian Wheezy 3.2.0-3-686-pae Kernel
I just downloaded SimpleIDE-0-7-2 (beta) from sites.google
$ tar -xjf SimpleIDE-0-7-2-1.x86_64.debian64-dev-linux.tar.bz2
$ cd SimpleIDE-0-7-2
Since i have Debian, and I don't want sudo, I do
$ su -
# ./setup.sh myusername
Installing ./simpleide as heich
Found Users /opt/parallax/bin
Setup complete. To run program use: ./simpleide
# exit (from root)
$ ./simpleide
Here is the error msg:
/opt/parallax/SimpleIDE-0-7-2/bin//SimpleIDE: 1: /opt/parallax/SimpleIDE-0-7-2/bin//SimpleIDE: Syntax error: "(" unexpected
from the previous line, i realized that there is a double backlash on the path concatenated in simple ide:
`$dirname/$appname "$@"` &
If i remove that double backlash, i'm still receiving the error msg.
As a test, i installed the propeller GCC libraries on /opt/parallax. Same results
Am I doing something wrong?
Best regards
Hector
$ su -
# exit (from root)
$ ./simpleide
Best regards
Hector
Version 0-7-2 is quite old. There are newer distributions here https://code.google.com/p/propside/downloads/list
The latest package setup scripts (v0-8-5 for example) automatically copy the propeller-gcc distribution to /opt.
Please try the v0-8-5 distribution if you can.
I'm not really sure why you're getting a syntax error when starting the 'simpleide' script.
The simpleide script sets the LD_LIBRARY_PATH and starts the bin/SimpleIDE application.
Perhaps you can do these steps separately without the script?
Double backslash should not mean anything unless wheezy has some change that treats it as special.
I don't have a wheezy virtual machine and space for more VMs is disappearing.
I've asked Daniel to install a Debian wheezy for another issue. Maybe he can help with this.
--Steve
Hello Steve!!
Early morning today, searching for the source code, I went to propside site, and i realized i was installing an old version, which i got from
https://sites.google.com/site/propellergcc/downloads/linux-downloads
I've downloaded -from the right site- 0-8-5-1.i686 but I could'n tested yet.
Please ask Daniel not to install another VM, only for Wheezy.
As soon i can, i'm going to try again. Also, i'm reading how to compile from source
Thanks and best regards.
