KiCad Schematic Symbols/Footprints
I havent acually sat down in front of a PCB Cad program in a while. I was just using PCB Express for my schematics and made my own symbols for common parts from the parallax store including the propeller.
Anyways I need to draw a schematic fairly quickly I know how to use KiCad I was just wondering if theres a good set of schematic symbols for the propeller and other common parts like regulators used around here. It would be nice if there were also matching footprints for the board editor. I could easily draw this stuff but i need to go as quickly as possible,
Have a look at the kiCad library site http://www.kicadlib.org/
Lots of good stuff their including a link to this KiCad library serach tool. http://per.launay.free.fr/kicad/kicad_php/composant.php
Just type "propeller" into the box and boom you find parallax_propeller.lib. Awesome.
Im trying to get a schematic done like right now, ive downloaded all the nessicary lib and mod files for parts I need via the search above. Im not sure how to add them to kicad though and cant find it in the help file. I tried just copying propeller.mod and .lib into the share/library and share/modules folder restarted kicad and couldnt find the chip...
Also is a .lib and .mod everything you need for the part in Eschema and PCB New
http://teholabs.com/knowledge/kicad.html
ive only used pcb express and made my own parts in it really easy but its definately not what i wanna get locked into
I also wrote some basic tutorials for those who've never used Kicad - and I was working with a Prop based pcb as well:
http://tymkrs.tumblr.com/archive
If you look in August and September it goes from step 1.
Thanks for that, I need to get to grips with Kicad again after a long layoff. I want to develop a few bits for my ham radio shop.
Cheers
Richard G3CWI
___________________________________________________
Portable Ham Radio accessories http://www.sotabeams.co.uk
I found the library at http://per.launay.free.fr/kicad/kicad_php/composant.php
Then added the Library to KiCad
But when I try to use the library I get the following errors.
What is the specific library that you tried to add?
Also, have you tried defining your own library? It's not that hard, and it's pretty quick once you get the hang of it: http://kicad.rohrbacher.net/quicklib.php
I am trying KiCad for the first time.
These are the libraries I was trying to add:
P8X32A
http://library.oshec.org/compressed/all.tar.gz
P8X32A-D40
P8X32A-DIP
P8X32A-M44
P8X32A-Q44
parallax_propeller-P8X32A-D40
parallax_propeller.mod
parallax_propeller-P8X32A-M44
parallax_propeller-P8X32A-Q44
I want to add a 40 Pin Propeller Chip, Crystal, EEPROM, etc... so I can layout a small Propeller Board.
I have not tried yet defining my own library, thank you for the link to the Quick KICAD Library Component Builder
I am using windows version "KiCad Build 2012-01-19 BZR 3256) - stable"
See picture below for my KiCad "About" Screen.
Thanks SRLM, I was able to create a part/library using the "Quick KICAD Library Component Builder : Assign Pins " at http://kicad.rohrbacher.net/quicklib.php, and was able to use it in KiCad.
Here is a picture of the part I created:
Thanks for the link Circuitsoft. I will have to try updating my KiCad installtion, since I still would like to import the existing premade ".lib" and ".mod" files
