Can a propkey program an arduino?
Ok so I got this ardunino kit and im waiting on the programmer. I wanna mess with it a little and I have about 5 options, looking at all my parallax hardware, and avr programmers... and even a bus pirate. But i wanna keep this simple I have no desires to build a max2323 adapter although i have the parts for that too, seems dumb since the programmer is coming.
Looking at all the tools at my disposale using a propkey with the wire broken out and connected to the arduino seems simple enough, as this ardunio kits header only has rx tx +5 and G, I guess what im afraid of is that the FTDI is set to do 3.3v on the propkey and the arduino will fry it. Im not sure if this is the case of if ftdi does auto level shifting like a good max chip. If this doesnt work the next easet option is to use the Bs2 Db9, but this soultion will was a pcb mount serial connector.
RDL2004, many Arduino clones dispense with the on board TTL serial to USB chip and use a Propkey like solution. It saves money and eliminates the full size USB jack which can short some shields.
Exactly. Many Arduino clones just leave off the USB interface and require the user to provide a 5 volt TTL compatible signal.
