How to cooperate Spin with Assembly
Hi, I am doing a project collecting 24kHz data and storing the data into SD Card. I am currently using the "fsrw" package, but the speed is not fast enough. I realize that there is a fast read and write code in the safe_spi file using assembly code, but it seems not to be cooperated into the main fsrw file. I tried to use the part, but SPIN and Assembly do not share the functions. How could I cooperate this code into my main file?
Thanks!!
Thanks!!
you did not give much information about what you try todo with spin so I am just guessing. 24kHz is rather fast for spin! So perhaps it would be better to switch to a compiled language!
Perhaps it would be good to check in an early stage of your project.
Good luck!
Christof
