TSL1401 how to connect sensor
I am beginner. I have no idea how to connect some of the pins and I think there is no answer in any datasheet.
Precisely I want to know what to do with:
VDD
TR
SD
ST
SI
GND
SO
SC
CK
AO
+5
Of course I know that i have to connect three signals
SI, AO, CLK
of course GND -0 and +5
and probably VDD to +5
but rest??
could you describe everything very precisely?
Piter
VDD
TR
SD
ST
SI
GND
SO
SC
CK
AO
+5
SI, AO, CLK
but rest??
Piter
Supply voltage and exposure time are independent. Regardless of the supply voltage, the same amount of light exposure will produce the same output voltage. The only difference is that, with a 3.3V supply, the output will saturate sooner than with a 5V supply. Because of that, if you're using an ADC whose reference voltage is Vdd, the TSL1401 will appear to be more sensitive by about 50% at Vdd = 3.3V than at 5V. But that's a function of the ADC, not the sensor.
With the stamp both Vdd and the 5 volts pins of the DB expander are connected to 5 volts. But with the Propeller I connected Vdd to 3.3 volts and 5 volts to 5 volts. This runs the camera off 3.3 volts and A0 can connect to the ADC on the Prop Boe, but 5 volts is available in the mezzanine connector for my transistor controlled super bright LED. The transistor will be switched on by a Propeller pin, but the LED gets its power from 5 volts through a resistor.
Basically I don't want to let any magic smoke out of the Prop BOE since I am mixing 5 volts and 3.3 volts in this manner.
Thanks Phil. I shall try this tonight.
