Cog Start and Stop question — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-09-24 13:38 in Propeller 1
I have a main object and within that main object I have a method that if I want to start calls object1 that launches in a new cog and within object1 it launches 2 additional identical objects (objects 2 & 3) into their own new cogs to work with object1.
My question is if I stop (cogstop) object1 does it automatically stop objects 2 & 3?
If it doesn't do I need to keep track of cog ID's so that I can stop them individually by number? I know I can get the ID's returned to me on startup so I am guessing I can assign them to a variable and address them (cogstop ID) that way if needed.
Thoughts?
Don
    edited 2012-09-24 11:48
    If object1 is properly written, it will have a stop method that also stops anything that it started. But you will have to look at that object to see if it does that. There's no way that we can guess from your post how that object is written.
    edited 2012-09-24 12:08
    I think the question is whether a cogstop on one cog will also stop all the other cogs started by that cog. The answer is no. A cogstog will only stop one cog. As Phil suggested, you should have a stop method that will do an orderly shutdown of all the cogs you want to stop.
  • Don MDon M Posts: 1,654
    edited 2012-09-24 13:02
    It hasn't been written yet....
    edited 2012-09-24 13:03
    Dave Hein wrote: »
    Dave that is exactly what I was wondering. I think I know what to do. Thanks.
    Phil- I found your COG_counter.spin method. Works great to troubleshoot in this experiment. Thanks!
