Generating A Step Table
pogertt
                    In the Stepper Motor Program
http://obex.parallax.com/objects/682/
there is a step table for controlling the time between steps of the motor while it is accelerating.
The table provides the delay times for how long to wait before issuing the next step pulse when accelerating or decelerating the motor.
I would like to be able to generate a new table, with different acceleration rates, different final speeds, and different number of steps.
The table provided starts the first step at approximately 31.6 Steps per Second, and accelerates the motor to 1,000 steps per second in 0.5 seconds.
I am looking for some help as I am having difficulties understanding the acceleration formulas.
dat
Segments                long    250    ' How many segments in the Ramp table
STable                  long    2529822,1047887,804072,677864,597210,539919,496507,462137,434049,410534
                        long    390471,373090,357842,344324,332231,321330,311435,302402,294113,286469
                        long    279393,272816,266683,260946,255564,250502,245729,241219,236949,232897
                        long    229047,225382,221887,218549,215358,212303,209374,206564,203863,201266
                        long    198765,196356,194032,191788,189621,187526,185498,183535,181633,179789
                        long    178000,176263,174576,172937,171343,169792,168283,166813,165381,163985
                        long    162625,161297,160001,158736,157501,156294,155114,153961,152833,151730
                        long    150650,149592,148557,147543,146549,145576,144621,143685,142767,141866
                        long    140982,140115,139263,138426,137605,136798,136005,135225,134459,133706
                        long    132965,132236,131520,130814,130120,129437,128765,128103,127451,126809
                        long    126176,125553,124939,124334,123738,123150,122571,121999,121436,120880
                        long    120332,119791,119257,118731,118211,117698,117192,116692,116199,115712
                        long    115230,114755,114286,113822,113364,112912,112465,112023,111586,111154
                        long    110728,110306,109889,109476,109069,108665,108267,107872,107482,107096
                        long    106714,106337,105963,105593,105227,104865,104506,104151,103800,103452
                        long    103108,102767,102430,102095,101765,101437,101112,100791,100472,100157
                        long    99844,99535,99228,98924,98623,98324,98029,97736,97445,97157
                        long    96872,96589,96309,96031,95755,95482,95211,94943,94676,94412
                        long    94150,93891,93633,93378,93124,92873,92623,92376,92131,91887
                        long    91646,91406,91169,90933,90699,90466,90236,90007,89780,89555
                        long    89331,89109,88889,88670,88453,88238,88024,87811,87601,87391
                        long    87183,86977,86772,86569,86367,86166,85967,85769,85573,85377
                        long    85184,84991,84800,84610,84421,84234,84048,83863,83679,83497
                        long    83315,83135,82956,82778,82602,82426,82252,82078,81906,81735
                        long    81565,81396,81228,81061,80895,80730,80566,80403,80241,80080
                        long    80000 ' Traverse Speed (80_000_000/80_000 = 1000 steps/second)
Where s is distance (or angle for rotation), a is acceleration (or angular acceleration). Since steps correspond to distance you invert the formula to get times:
t = sqrt (2 Ns / a).
[N is the number of steps, s is the distance per step]. Then your step tables are merely differences between successive t values as N increases:
However there's another way to determine when to step using DDS (direct digital synthesis) - you incrementally calculate s each time t increases and compare to see if a step is due. Calculating t squared incrementally only takes addition since (t+1)^2 - t^2 = 2t+1. You can use this dynamically and eliminate the need for tables and it works for different accelerations.
Bruce
EDIT: And this formula has worked well for me. If you exceed 5 revs per revolution, your motors will stall and whine, or at least mine did, but I had Applied Motion stepper motors, controlled by Gecko Drives.
EDIT: OOOPPPSSS That was for maximum acceleration/deceleration! Your minimum acceleration/deceleration can be anything above 0.
EDIT: In addition to my previous comments, you do not need tables to create a ramping profile. You may want to take a look at this source code to see how ramping can be achieved programatically.
http://forums.parallax.com/showthread.php?138282-StepperDriveErz
then create a xy-chart from these values then there is an option to add an aproximation-curve. you can choose from different functions linear, polynom, exponential etc.
from this you should get a good aproximation-function to reproduce the values. Then you can start to tweak the parameters of this aprox.function to your needs
best regards
Stefan
Co is the starting seed value in the table.......2529822
Cn=Co
Errm, if you have a little patience... I'm currently working on a new step/dir signal generator that I plan to release as obex. It will probably overlap with the work of idbruce somehow. As a true propeller enthusiast I tend to start coding immediately when I have an idea instead of seraching the web if somthing already exists...
It will support
* multiple, synchronized axes (1 cog/axis), targeted for CNC applications
* step frequency up to 4MHz (useful for servos)
* no need to adjust pulse timing, always 50% duty cycle, guaranteed dir to step setup&hold times
* any trajectories, (linear, circular, free shape), well, not really, I mean it doesn't calculate trajectories, you have to feed the coordinates. But at least it's not limited to linear moves from stop to stop. Speed and direction can be changed on the fly.
* adjustable acceleration/deceleration ramps without (static) tables
I don't quite follow the logic behind this limit of 3-5 revs/rev. Are those in RPM? That would give a max acceleration of +16pulses/sec^2 on a standard 200 steps/rev. Did the engineer give any references to study?
According to theory, the amount of maximum acceleration/deceleration is in fact a matter of the "remaining" torque you have available in the motor for your given system (Driver+motor+load), i.e: At any given speed the driver+motor is able to create X amount of torque, some is used to bear friction losses. What is left is the only force you can use to change your loads speed and what you really need is a function of inertia and desired acceleration.
See the theory here Formulas for stepper motor calculation.pdf
I plan to release a PASM driver (steps/dir) which does ramping on a step by step basis with which I can drive more than 600 steps/sec^2 (on my system, YMMV)
Precise ramping is the key to success so you don't create "bumps" in speed which would require a much higher torque to effectively force the load to a sudden speed change (if your system cannot handle it then it loses synch with the steps)
Alex
No, it is not RPM, but pulses. For example, using a step angle of 1.8:
- 5 Revs per revolution
- Maximum ramp increase would be increments of 1000 full steps, but in my case, since I was using Gecko G251X microstepping drives, with a resolution of 1/10, that equated to 10,000 microsteps.
- 4 Revs per revolution
- Maximum ramp increase would be increments of 800 full steps, but in my case, since I was using Gecko G251X microstepping drives, with a resolution of 1/10, that equated to 8,000 microsteps.
- 3 Revs per revolution
- Maximum ramp increase would be increments of 600 full steps, but in my case, since I was using Gecko G251X microstepping drives, with a resolution of 1/10, that equated to 6,000 microsteps.
No, he did not give me any references, since I was just looking for a quick answer on obtaining maximum speed with no load. Actually, I believe the maximum speed with no load and with the combination of the G251X Gecko drive and the HT23-400 Applied Motion motors was 4.5 Revs per revolution before I started losing steps. Of course, the maximum speed that can be obtained before steps are lost will be contingent upon the load.Bruce
EDIT: OOOPPPS that is wrong. Those steps would be divided by 200 full steps or 2000 microsteps. So:
- 5 revs per revolution
- 10,000 microsteps / 2,000 microsteps = 5 microsteps added per microstep until maximum speed is obtained.
And so on....EDIT: And of course these steps directly coincide with the pauses between pulses.
Bruce, I believe there's a time unit missing in the equations. Speed is measured in angle/time (e.g: steps/sec, RPM, etc). But acceleration is measured in angle/Sec^2 (or Speed/time), so a 5x speed increase (5 microsteps per microstep) needs the time interval over which such an increase occurs.
I have achieved no load accelerations of about 1000 fullsteps/sec^2 (i.e: the speed=frequency increments 1000steps each second in a linear acceleration ramp up to the speed limit of my PSU+driver+motor combination (about 22000 microsteps/sec @ 16microsteps/fullstep ~= 412RPM))
Alex
Ramping is achieved by increasing or decreasing the pauses between pulses which coincides with the increment or decrement of the microsteps, and further directly affects the number of pulses in a given period of time.
Study the drivers above, learn how to use them, and you can achieve very nice speeds and ramping profiles.
EDIT: However it is worth noting that I am pumping 48V through a 50V drive.
Manatwork, have you completed your step/dir signal generator?
I couldn't find a step/dir in OBEX.
Is it under a different name or posted in the forum?
Thank You
Mickster
I have posted questions and PPM you directly with no replies. If this is a sore spot for you just say so.
I was asking if you ever finish that code (Step/Dir signal generator for CNC) or was it replaced with something else?
Was there anything more than the partial demo posted in 2012?
I didn't see you(Manatwork) on the obex. Did you use your real name?
Did you post it on the forum?
Thank You
Here is the link i found (03/05/2019) to the post.
https://forums.parallax.com/discussion/123946/eagle-drd-file-parsing-engine
The file "StepperDriveErz.zip" is in the third post down.
Ooops, I haven't seen them until today. I don't read every discussion in the forum and I also haven't found a way to get email notifications if there is a reply to one of my posts.
I've replied to the other topic: http://forums.parallax.com/discussion/142705/step-dir-signal-generator-for-cnc
