Prop controlling electric wheelchair motors?
                    I have an old wheelchair that I tore apart and assembled to an old go-cart frame just because I was bored, but recently, I wanted to see about adjusting the turn speeds in the controller and accidentally shorted out the main brain with a meter probe
   Now that the controller is dead, I want to see about building my own but I am not sure what MOSFET's / Transistors I can use to drive the motors.  In the controller, there are IRF1010N's which are rated at 60A but the controller gets really hot after about 5 minutes of driving it around.  What I am hoping to find is an already assembled H-Bridge that can handle 100A which can be controlled by the Prop directly without other chips needed.  If that is not available, I would need to build an H-Bridge, but I don't know what Mosfet or transistors I can use.  Any help on this?
EDIT : Voltage is 24V powered by 2 wheel chair batteries.
BIG modules tend to be 3 phase, and not cheap. Often they are only the FET Brick, so you still need a Driver IC.
Probably best to get a Motor Driver Controller from one of the usual suspects (Allegro, Infineon, OnSemi, IRf etc), and add your own FETS.
Ideally one with a inbuilt charge pump, so you can drive to 100% duty - and one that can set a Current limit is easy to control.
Then you can choose FETS to suit, and you can get sub-milliohm FETS for sub $1 in volumes, and parallel as needed.
( those IRF1010N look to be 11 mOhms )
http://forums.parallax.com/showthread.php?139811-R-C-5-channel-radio-and-receiver-to-control-24v-DC-motor
I was able to adequately drive my 120 lb wheelchair based robot on 12V using HB-25s (300W). It was easy however to create a situation where the controllers would shut down. Using 40A 24V (960W) controllers will allow over three times the power to the wheels which I expect will be more than enough for whatever I need it to do.
If you need a good reference design for an H bridge driver using discrete components, go to GE site and grab the service documents for an AMX4+ portable rad unit. The system uses a pair of H gridge drivers using the IRF-250 (30A max) to move the thing at a pretty good pace. Its normal rated weight is 1080lb. The system is using internal gel cell batteries stacked to 115V (9 12V 28Ah). But then again, that may be part of your problem. It may be better to use smaller batteries arranged to give you a higher voltage to drive with and enable a lower rated current to the motors. These motors are 120V PM motors and weigh in about 7lb. As I mentioned, the AMX4+ is a half ton of machine. this is a rather nice device from the service point of view in that all the detailed schematics are there so you can also figure out how the drives are controlled by the pre-amp board. Lot of other parts provide good working examples if a bit dated though.
FF
You may have missed this detail, it is no longer still a wheelchair !
and assembled to an old go-cart frame ...
What did I say that requires it to still be in wheelchair form?
QUOTE : "Then you can choose FETS to suit, and you can get sub-milliohm FETS for sub $1 in volumes, and parallel as needed."
Does this mean I can "stack" 2 of these IRF1010N's and make the controller handle more power? If so, I can order a bundle of 10 for about $1 a piece.
From the spec sheet, it appears that the gate only needs 2 to 4 volts to fully activate the MOSFET. Does this mean they can be run directly from the output of the Prop?
While tinkering with the old controller, I attempted to activate one of the h-bridge circuits manually by tapping onto the pads where one of the chips was located which I suppose activated the h-bridges based off of input from the main processor. I removed both chips with my hot air station to ensure I would not short anything out. Once I powered it up, I checked to make sure power was where it needed to be then accidentally touched one of the wires I soldered on which caused one of the mosfets to explode
You can buy better FETs than IRF1010N, but you can parallel like-FETs; if they are on the same PCB, then PCB traces provide some sharing resistance.
If you are trying to lower power loss, 3.3V gate drive is not going to be enough.
http://www.dimensionengineering.com/products/sabertooth2x60
Here is the link : http://www.digikey.com/product-detail/en/IRFB3207ZPBF/IRFB3207ZPBF-ND/1300656
In the specs on that page, it shows : Vgs(th) (Max) @ Id 4V @ 150µA
Does this mean that a 4V 150uA input at the gate will fully activate the mosfet?
It says :
VGS(th) Gate Threshold Voltage 2.0 V(Min) ––– 4.0 V (Max) VDS = VGS, ID = 150μA
Which means the worst case (max) FET could draw only a teensy ID = 150μA, at 4V VGS,
ID is the DRAIN current, at that Gate Voltage, and the spec is the threshold
Find the Rds value, which says 3.3mOhms, for 10 V on the Gate. ie you WILL need 10V to drive this FET.
You are paying the cost of development across however many units are expected to be sold plus some profit on the sale plus the cost of stocking parts and support infrastructure the company expects for the device plus any regulatory costs....... etc......... all part of the cost of doing business. Because the developer expects to make a profit, guess who gets to pay a percentage of these costs. Pay da man...... Or spend the money and develop it yourself, putting in the design time, the parts you have let the smoke out of and so on. Which way will cost you less and which way presents the reliability level you can tolerate.
FF
My standard advice for MOSFETs is:
1) Check the voltage spec is twice the supply voltage (more for inductive loads).
2) Check the Rds(on) value will lead to a low-enough power dissipation for the currents you'll be dealing with and the heatsinking you'll be using.
3) Check the Vgs needed to achieve that Rds(on) - if its 10V you can't drive from 5V, if its 4.5V you can drive from 5V (but it'll be dodgy from 3V3).
4) If using PWM calculate the switching losses and choose a frequency and a gate-drive current that'll ensure the losses aren't dominant (typically
the device is spending less than about 2% of the time actually switching - for high power loads this is more important - during switching the device dissipates far more power than at any other time.
You can pretty-much ignore the current rating, if you follow item 2) you already have ensured this will be fine (slight caveat unless using low-duty cycle high-current pulses).
Don't go by the threshold voltage, follow 3)
Note that typically the fully-on Vgs will be around 3 to 4 times the Vthr for most devices.
The total gate charge divided by the gate drive current will tell you approx how long switching takes. 10nC / 10mA = 1us, 200nC / 1A = 200ns etc etc
