Question about the Wiznet Chip
Is it possible to use the Wiznet chip to create a device that I could change the IP address on. I have an idea for a tool but I would need to be able to type in a different IP address on the device I create and on the device it connects to.
so - yes you can do exactly that what you asked for.
Enjoy!
so it boils down to what your other devices are producing (as HTML-text) and if you can display this on your own on a display.
you basically need to write a web-browser for th Prop!
On the other hand if your devices just use simple HTML with - let say - some sensor values at specific positions, then you can parse the text, pick your values out and display them on your screen.
as allways - yes and no...
Enjoy!
So yes... perfectly doable but an IP address is not the only thing required. As msrobots pointed out, it might take some work to parse the HTML returned by the server.
Describe your project in more detail.
