making your own auto-docking/battery-recharging thing for your robot
Jim the Hermit
I've always wanted a robot that would recharge itself when the batteries are low. Where can I find how other people did it?
I can envision something similar to a cell phone battery that is simply held into a pocket and the connections are spring terminals (or a laptop battery as well). Design a cartridge style battery pack that is held into your robot with some sort of cam-lock mechanism. When docked into the "fuel transfer station", a servo driven "key" would engage into the cam-lock to "unlock and disconnect" the battery pack. A second set of servos in the dock could pick up the battery pack and place it into a similar setup in the dock for charging. Then drop in a second battery that is charged, engage the cam-lock, and send the robot on it's way. I could see the entire battery transfer process taking less than 2 minutes.
You may need to add 1 or 2 servos to your bot for the battery pack if a cam-lock setup won't be sufficient to give you a good enough connection for your current draw (the servos could engage stiffer spring terminals that could handle a greater current draw.) Of course that would mean your bot needs power while transferring so some sort of power through the "key" would need to be available.
Jim,
I recall seeing a few posts on the forum with similar thoughts and after doing a forum search for "docking", I found the ones (and then some) I was thinking of:
http://forums.parallax.com/showthread.php?102086-Scribbler-Auto-Docking-Videos&highlight=docking
http://forums.parallax.com/showthread.php?141640-Need-dock-charger-for-Eddie-amp-laptop&highlight=docking
http://forums.parallax.com/showthread.php?140100-Docking-Station&highlight=docking
http://forums.parallax.com/showthread.php?129512-Robot-to-determine-location&highlight=docking
http://forums.parallax.com/showthread.php?116096-Recharging-batteries-while-the-robot-is-powered-on.&highlight=docking
http://forums.parallax.com/showthread.php?105120-auto-docking.&highlight=docking
video http://www.youtube.com/watch?v=ujjgV6sTvo4
http://cres.usc.edu/pubdb_html/files_upload/237.pdf
http://homepages.inf.ed.ac.uk/rbf/CVonline/LOCAL_COPIES/BARNES/dock.html
http://www.schursastrophotography.com/robotics/dockinglogic.html
http://www.pelebot.org/pelebot/Buildyourpelebot/Powerandbatteries/Dockingstation/tabid/62/Default.aspx
http://www-ist.massey.ac.nz/conferences/icst05/proceedings/ICST2005-Papers/ICST_151.pdf
I was going to point you to erco's idea but realized he already did that after the post!!!!
When I was a kid, I imagined a robot plugging itself into a station for power. It'll then put it's dying battery pack onto a turntable. The table would have a another fully charged pack on the other side, and turn 180 degrees. The robot would pick up and install the new battery and the station would begin recharging the old one.
http://forums.parallax.com/showthread.php/147399-Gel-Cell-Charger-Deals
I'd be tempted to build the charger into the robot and make the bot plug itself into a 110 VAC outlet.
My next project!
