Fixing instruction overhead time?
So Im in chapeter 3 of the wam book and I went off and wrote the two player reaction game as an exercise at the end here it is
Anyways in the loop thats checking in3 and in4 is having time issues. Those two if commands back to back along with the counter1 and counter2 assignments are getting all messed up as far as time. If i hold the buttons for 3 seconds i only get about 1700ms stored in the counter variables. Is there a fix for this?
' {$STAMP BS2} ' {$PBASIC 2.5} '2 player reaction counter1 VAR Word counter2 VAR Word counter1 = 0 counter2 = 0 DEBUG "Both players press and hold there",CR, "button until the light turns red.",CR, "When the light turns green let go",CR, "of the button as fast as you can!",CR, CR DO DO LOOP UNTIL (IN3=1) AND (IN4=1) HIGH 15 LOW 14 PAUSE 1000 HIGH 14 LOW 15 DO IF IN3 = 1 THEN counter1 = counter1 + 1 ENDIF IF IN4 = 1 THEN counter2 = counter2 + 1 ENDIF LOOP WHILE (IN3=1) OR (IN4=1) DEBUG "Player 1's Score is: ", DEC counter1, " mS!", CR DEBUG "Player 2's Score is: ", DEC counter2, " mS!", CR IF (counter1 > counter2) THEN DEBUG "Player 1 is the winner!", CR,CR ELSEIF (counter2 > counter1) THEN DEBUG "Player 2 is the winner!", CR,CR ELSEIF (counter1=counter2) THEN DEBUG "Tour were equals this round!", CR,CR ELSE DEBUG "WTF HAPPEND!?", CR ENDIF DEBUG "Play again? Just hold down the buttons again!",CR,CR LOW 14 LOW 15 LOOP
The result will not be exactly in milliseconds, so if you want it to be, you have to multiply by a calibration factor. For example, you said, "1700 in 3 seconds". That is 567 per second, and the conversion factor then would be ms = counts * 1000 / 567. That is, if the counts come out at 567, that means the button was pressed for 1000 ms. The BASIC Stamp can do that multiplication by using the */ operator.
ms = counts */ 451
where on a hand calculator 451 = 256 * 1000 / 567. If you change the counting loop, you will have to recalibrate.
Should the person who releases the button fastest be the winner?
Ahhh thank you, the WAM book has not gotten this detailed with syntax yet! Kind of weird the end of chapter project would be a game you couldnt possibly get right with what theyve taught you, my source looks alot similar to the solution except I used and while OR instead of an until AND. Lol i did mess up the signs on the code to determine a winner didnt catch that
So is there a way to calculate just how many instructions/cycles code will take so problems like this are easily avoided? Would an even better way to do this is to use a 74 series counter to keep track of elapsed time? My first uController is the prop and it seems much more accurate not to mention fast
It can get thrown off if there are branches that can take a program down different paths within a loop. Your original with the IF statements is okay, given the situation, but after the fastest player releases the button, it takes a different time to go around the loop than it did before the first player timed out. That is because an IF statement that was true, is now false, and one of the counters no longer has to be incremented. The way I wrote the code is more neutral. Both counters are serviced each no matter what, adding either 1 or 0 to the count.
The Stamp does not have an internal timer per se, so you are right to wonder about adding an external timer for that, if need be. The Propeller has multiple very capable internal timers and counters.
