LCD Monitors failing, Bad Caps?
rwgast_logicdesign
Ok well let me say first of all there is bad caps in the monitor im looking at there all puffy! But im not sure if its the main issue.
Anyways today I went to get a glass of water came back and my monitor had a red vertical line down the left side!! I looked on google some people said that happens when the amplification chips go bad but im not sure about all that.. anyone know what causes this, it definately the monitor the line stays when the vga cable is unplugged.
So I had another monitor I got from a friend that was better anyways. He got it from me along time ago it worked fine! He said within two weeks it just wouldnt turn on. I flipped it on and it came on but it looked like half the pixels were dead literally half or more... I know the major symptom of bad caps is the power supply just not working could it still be the caps causing this dead pixel like problem? The caps are bad for sure 4 out of 6 25v 470uFs are puffy and one 220uF is swollen! I was gonna order some decent panasonic caps and replace all the power supply caps in this monitor. Does it sound like theres more going on than the caps? I cant really afford a new monitor right now but I can afford a few caps so Im hopping this isnt a problem with acuall dead pixels. I had another friend with this exact monitor and it developed a huge black patch of dead pixels in the corner maybe the size of half a dollar bill, just happened over night.
If the caps are not low ESR then it probably just the caps. If the caps are low ESR it can still be the cap but is less likely you'd have more than one go bad.
If there are any inductors around the caps check the film over the visible part of the coil and if there is discoloration. Check the entire board with a magnifying glass and visually inspect every component. Sometimes caps bulge from the bottom and the top looks normal. If you see anything else on the board discolored or burnt then it is probably not the caps.
Make sure you monitor it after you replace the caps, I would suggest leaving it powered off (better yet unplugged) when you aren't around for at least 100 hours of use.
It's a long shot but you can also test the failed caps for a short. I don't know if caps can fail closed, I should probably find out. It's seems if one did it may damage other components.
Can you take a pic of the pixel issue and post it? Usually dead pixels don't group up unless there is a connector issue or physical damage. When computer video cards go bad you get some artifacts that make it look like your monitor has gone mad. I've seen cards that artifact that you could fool anyone into thinking the LCD was bad haha. Bad power supply could cause that all to happen but I'm interested to see the actual bad spot in action.
On desktop monitors, I don't know...
It can in some cases be caused by a bad connection to the panel itself, but fault-finding this without causing additional damage is just about impossible.
I have a little TV box that converts cable to my VGA. It failed and was very hot. I checked the caps and they looked bad. So I replaced all AND increased both the quality and the high voltage tolerance of them to assure long life. With voltage regulators or switchers involved, you should not mess with increasing the microfarads, but you can do some enhancements.
The little TV box works fine now and has for over a year. Replace ALL the electrolytics, not just the puffy ones as others may have failed or are near failure as well. Visual inspection is not enough to decide good or bad.
I would not bother with a lot of research until after I got the caps replaced and saw how the monitor behaved. Digital devices can just be too quirky due to bad power.
If problems persist, I would use a spray tuner cleaner to remove any dust or carbon build up on the circuit boards. That is a big air pollution problem where i live and I have had to clean one monitor about once a year as carbon in the air from steel mills shorts the fine pitch leads on the chips. You can confirm it is dirt by slapping the side of the monitor and seeing it start to behave normally for a while. The slapping shakes the dirt loose for a few seconds.
More recently, I replaced all the push buttons on my 5 year old air conditioner as they were no longer working right. These are cheap parts as well and amongst the first to go. Before their replacement the a/c was behaving very oddly due to the microcontroller being confused, now it is fine. Shops wanted me to buy a new A/C as it just had its warranty period end.
For an over-voltage situation the cap fails open and nothing gets fried, it is like a cheap surge protector. If there is an issue with high voltage the higher voltage cap will no longer fail, something else will. I'd rather have a cap fail.
Same for temperature issues. If it's that hot it there then something else is wrong and it will need to be addressed.
from "Reliability of Capacitors", by Illinois Capacitors, Inc.
of course, if it would last long enough for you with the lower rating then all is good anyway.
Don't you think that if you beef up a failed part, and there is a problem other than that part, now that beefed up part will not fail, something else will? Maybe it is just me lol...
To me it is like saying I cannot run 15 amps over a 10 amp fuse, so I'll make it better by putting in a 100 amp fuse. I know a cap isn't a fuse but still...
Theory about having the cap fail rather than something else is rather dubious. Where is this higher voltage suppose to come from? And does the failed cap always do not harm? Sure, you can always argue lighting strikes, but if the unit is really protected that should not be an issue. If it is an issue, maybe nothing can protect the device unless the manufacturer has actually included the new scheme of MOVs and fuses together.
If the cost is no more, just buy to higher spec replacement. I usually do this with everything I keep on hand. It seems that caps of good quality have been evolving into smaller and smaller packages, so they can fit in where they may not have in years past.
The main point of the upgrades may be that the manufacturer actually creates a warm environment and puts in caps near to failure voltages so the unit has a shorter useful life. Most of the components on a circuit board will just run nearly forever if given a chance - but the electrolytics and the switches are the weakest links and the first items to go due to age.
The only device I've been unable to revive by replacing failed caps has been a regular computer motherboard. I suspect that the complexity of multiple voltages inside the CPU may have gone haywire.
hi temp caps arent becuase if the monitor is getting hot enough for the caps at the correct rating to fail something other than the caps needs to be addressed, at the correct raiting caps ideally shouldnt overheat. which raises the question the hige 100uf 400v cap had white epoxy holding it on the boared in a fixed horizontal posistion, was that thermal i see it on some resistors too.. cuz i dont have any thermal epoxy only paste and unless digikey has it for under 5 bucks im not buyin any ill just use the best temp raiting i can get.
heres my outlook if i user higjer caps ill get more lofe if the manufacturer went as tight on the spec as they could (im assuming its so the brand is already bad so they probably didnt up the caps to save a few more cents) uping them will help especially since it gets to 120 here. if something else is wrong and is causing the problem i probably cant fix so might as well make it work till it goes dead!
No
This is done to secure the larger capacitors to the board mechanically. This keeps the stress off the solder joints.
A few things you need to keep in mind...
Electrolytic capacitors have one of the highest failure rates of any electronic component and the primary cause of their failure is heat. Electrolytic capacitors have a relatively high cost for passive components and manufacturers of electronic devices are always looking to lower their costs. Capacitors rated for 85 degrees are cheaper than 105 degree rated capacitors. Many manufacturers only care if their product makes it to the end of the warranty period.
Also, it isn't necessary to run an electrolytic capacitor at or above it's temperature rating to benefit from a higher rating. See post #12 above.
Basically, I do what I do (replace caps only upgrading ESR) because I am not highly skilled or trained with electronics. I have no idea what is going on in the circuits these caps are attached to. I'm definitely not trying to talk anyone out of experimenting with better caps, by all means do so. If I were to replace caps on my own gear, sure I'd consider making changes. The problem is my stuff never goes bad hahaha.
I have an issue with modifying hardware in people's businesses, I try to keep it as OEM as possible. As bad as it sounds, I'd rather stick to what the manufacturer put in there with the exception of the ESR rating. It's a matter of liability to me. There are too many unknowns. If I were to modify a board that much I'd need to hold it for lots of stress testing before I felt comfortable giving it back.
I hope this doesn't give you an unsettling view of how I do repairs lol. If the new low ESR replacement caps fail again I tell the person there is nothing I can do, issue a 50% refund, and they know all that before any work is done. Works well for me, literally no complaints over 8 years across the board for any repair of that type.
Since electrolitics are rather sloppy, a 16V device may barely be able to handle 16V and age faster to something less.
Heat is always the big destroyer of electronic components, so devices that can handle more heat are always better even if they are never exposed to higher levels of heat.
BTW, I am not in the repair business. If I fix it, it is a freebie for someone and no promises that it won't break again rather soon. Old stuff is old and often has more than one problem area. I once replaced a water pump for a girl on her car and soon after her clutch went out and she never believed it wasn't my fault. Repair customer can be impossible at times.
And yes, 85 degrees centigrade is hot, 105 degrees centigrade is painful hot, maybe melting thermoplastic.
