Working on a serial data logger and am stuck. Need some help and suggestions.... — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-09-17 19:39 in Propeller 1
I am trying to data log serial data (9600 baud, 9 bit). I am using a modified serial object modified for 9 bit. It has methods similar in function to FDS. I am running 2 instances of the serial object- 1 for the Master and 1 for Slave. The buffers bufm[36], bufs[36] are defined as word buffers in order to store the 9th bit.
The Master starts its communication with the 9th bit set so for instance a command (with checksum) of 0B would look like this: 10B 00B. The 1 indicates the start of the Master command. The Master ACK does not have the 9th bit set so it will look like this: 000.
The Slave response begins without the 9th bit set except for an ACK. The slave ACK looks like this: 100. The slave response ends with the last byte having the 9th bit set.
So what I tried to do was use these "signatures", if you will, of determining whether or not the 9th bit is set to figure out the begining or end of data strings.
Here is my code:
pub main  | d, c, i, j, num_bytes
  term.start(31, 30, %0000, 115_200)                    ' start terminal (use PST)
  pause(500)
  master.start(MSTR, -1,%10)                          ' start receiving master comms
  slave.start(SLAV, -1,%00)                          ' start receiving slave comms
  master.rx_flush
  slave.rx_flush
 repeat
   d := master.rx                                         ' assign d to data coming in from Master
   c := slave.rx                                         ' assign c to data coming in from Slave
   if(d <> -1)                                          ' look for any data coming in from Master
     bufm[0] := d                                       ' store d in Master buffer
     i := 1                                             ' initialize buffer i index counter
     repeat                                             ' repeat loop to store data into Master buffer
       d := master.rx_time(10)                            ' receive Master data into d
       if(d == -1) or (i => 36)                         ' until no data received or Master buffer is full
         master.rx_flush                                  ' flush Master receive buffer
         quit                                           ' quit receiving data into Master buffer
       bufm[i] := d                                     ' put d data into Master buffer position indexed by i
       i++                                              ' increment i buffer index counter
     num_bytes := i                                     ' assign number of i bytes to num_bytes
     term.str(string("M1: "))                           ' begin display for Master bytes
     repeat i from 0 to num_bytes - 1                   ' loop through Master buffer to display
       term.hex(bufm[i], 3)                             ' show 3 bytes of word to see if 9th bit set
       term.tx(32)                                      ' add a space in between data for clarity
     if (c <> -1)                                       ' look for any data coming in from Slave
       bufs[0] := c                                     ' store c in Slave buffer
       j := 1                                           ' initialize buffer j index counter
       repeat                                           ' repeat loop to store data into Slave buffer
         c := slave.rx_time(4)                           ' receive Slave data into c
         if(c == -1) or (j => 36)                       ' until no data received or Slave buffer is full
           slave.rx_flush                                ' flush Slave receive buffer
           quit                                         ' quit receiving data into Slave buffer
         bufs[j] := c                                   ' put c data into Slave buffer position indexed by j
         j++                                            ' increment j buffer index counter
       num_bytes := j                                   ' assign number of j bytes to num_bytes
       term.str(string("S: "))                          ' begin display for Slave bytes
       repeat j from 0 to num_bytes - 1                 ' loop through Slave buffer to display
         term.hex(bufs[j], 3)                           ' show 3 bytes of word to see if 9th bit set
       if (c & $1_00) == $1_00                          ' check if c contains 9th bit set to indicate end of data
         if bufs[0] == $1_00                            ' check to see if only a Slave ACK
           term.tx(13)                                  ' if so then just do CR
         else                                           ' otherwise wait for Master ACK and display it
           term.str(string("M2: "))
           d := master.rx
           term.hex(d, 3)
           term.tx(13)
It works fine as long as there is only 1 Slave device on the bus. If I tell the Master to look for an additional slave device (with a different address) that doesn't happen to be attached to the bus I start to have problems.
Here's a screen shot of just 1 Slave device connected and logging. M1: indicates the start of Master command. S: is the Slave response. M2: is the Master ACK response. Remember anything beginng with a "1" indicates the 9th bit set.
Now here's a screen shot showing another device with the address of 30 that is being looked for by the Master but is not connected so it doesn't respond and ACK the Master.
You can see in the 6th line that begins: M1: 130 030 130 030 .... 10A 00A S: 000 000 and so on. The 130 030 is the Master looking for device with the address of 30 that is not connected thus no response. What I want my program to do is if it doesn't get an ACK from a device then the display should look like this:
The program should just send a carriage return if it doesn't receive anthing from the device.
I know I'm not the smartest programmer and I have spent several days trying to add term.tx(13) in certain locations among a myriad of other things to no avail. I tried adding an "else" statement with a term.tx(13) to the "if (d<>1) loop and that didn't work.
I need another set of eyes to look at this for some guidance. Somehow it has to be determined when the Master has sent a command that is not responded to in a certain amount of time. i thought that was what rx_time(x) was supposed to do. When it timed out it sends a -1 to indicate buffer empty.
Maybe this whole structure is wrong.... Any ideas or suggestions?
Thanks.
Don
  • Don MDon M Posts: 1,654
    Well I knew as soon as I posted something the light would come on...
    In the beginning of the repeat loop where c := slave.rx, the .rx method will just sit and wait until there is any data which causes a problem when there isn't any Slave response.
    Here is my updated code that works quite a bit better but may still need further testing:
      pause(500)
      master.rx_flush
      slave.rx_flush
     repeat
       d := master.rx_time(2)                                         ' assign d to data coming in from Master
             c := mdbs.rx_time(2)
               d := master.rx
               term.hex(d, 3)
               term.tx(13)
           else
           term.tx(13)
    Any other suggestions welcome.
    Thanks.
    Don
