LED's in series help needed
TC
First off, I would like to apologize if this is in the wrong location.
I am working on a car tail light that use three different LED colors, red, yellow, and white. and I want it to be controlled using a micro-processor ( BS1, BS2, or prop). I want to use a LED driver from Maxim to drive them. But I am having trouble figuring out how many LED's I can put in series that will work for my needs.
The LED's are coming from "SupperbrightLEDs.com", there 5mm High Flux led's. there specifications are:
Red: Forward voltage 2.2V, Forward current 20mA
Yellow: Forward voltage 2.2V, Forward current 20mA
White: Forward voltage 3.2V, Forward current 20mA
I was planning on using Maxim's "MAX16835" LED driver. I think it will do the job, but I don't know how many LED's I can put in series per string.
I think I have the math right, 13.8V(accounting for alternator running) / 2.2V (for red and yellow led's) = 6.27 LED's per series string. and 4.3 LED's per series string for the white LED's.
I understand that the MAX controls the current, but I don't know if it can handle 6, or 4 LED's per series string. I could not find any info on this question, so I was hoping someone here can help me.
TC
http://www.maximintegrated.com/datasheet/index.mvp/id/5751/t/al
TC
4 leds in series = 20mA, and 17 series strings in parallel = 68 LEDs = 340mA
You may also want to measure the forward voltage of each led so you can make the strings with forward voltages as well matched as possible.
TC
