Get Yer Hero Jr Right Here
http://www.ebay.com/itm/Heathkit-Hero-Jr-Free-Ship-/150900495638?pt=LH_DefaultDomain_0&hash=item23225ed516
Decent price if it works and you get it for under $400. Free ship.
Robert
I guess you've never seen one working before. It was meant to be a home/personal robot and had quite a few built in routines to act as a security guard, play games, and act like a robotic pet. There was also a library of programs on cartridges (12 different ones) that had a variety of routines for the robot from BASIC programming, educational games, and even an exercise partner. It can also talk.
Once you start adding on all the equivalent features and talk a comparable size (with finished body panels) then you can make a valid comparison. Otherwise it is like comparing apples and oranges. Different classes of robots. Small robots can cost less. Larger robots may cost more.
If the chassis is in good shape that alone is worth some money.
Odometry was never HERO Jr's (or HERO 1) strong suit. It had tricycle steering, one steerable drive wheel and 2 free-rolling wheels. It didn't go straight reliably, as there was no hard centering stop or switch on the steering mechanism. It used a geared stepper motor for steering, and a leaf limit switch for each full left of full right steering stop. It counted pulses between extreme limits and used half that count for a center position. You could manually bend the leaf spring limit switches to tweak it, but it was never 100% satisfactory. An accurate center position switch would have made all the difference in the world.
Robert is right in that there was a lot of software for various applications & games in the form of plug-in cartridges. HERO Jr. wasn't marketed to the experimenter/hacker like the HERO 1 was. The Votrax voice was high quality and fun to play with. Hardware wise, though, it didn't have tons of sensors or I/O. PIR sensor, microphone (handclaps), voice, one Polaroid sonar unit, wheel encoders, one photocell, 8 LEDs, 4 button radio control, and a battery voltage sensor.
You could actually do more with a BoeBot or even a Scribbler 1 with some hacking and some programming.
http://letsmakerobots.com/node/31158
It's 6/10 the size of the original, but seems like it's just as functional. I'm surprised no clones using modern components of the Hero have popped up.
I believe there is one in the works but its not completed quite yet......
Robert
