Diptrace schematic for basic Prop setup - all through hole components
I hope the title says it all - I'm looking to start with a basic Propeller schematic and make a few of my own boards (maybe) and rather than re invent the entire wheel I was hoping there might already be a starter schematic out there? again I want all through hole stuff
if not I will do it - but just wanted to see if anyone knew it already existed
Jamie
Jamie
http://smorgasboard.wikispaces.com/Designs
several of these look to be in Diptrace format, including my favorite, Propeller Platform USB...
cool username, btw
Ok, I see you want all through hole now...
Actually, making a DipTrace version of the original Propeller Platform would be nice...
Maybe it exists already, but I don't think I've seen it...
It uses the same pin interface of the propeller platform, but the 5V stage is not used.
You have Xbee, DIP propeller, uSD, and some other TH components.
Filter caps, pullups and eeprom are SMD, but it should get you started.
I adapted the same board for a heated bed control for my 3D printer (hope to post something soon), and it worked in both occasions.
The propeller is quite forgiving, only remember the filter caps!!
Massimo
(removed invalid schematic)
OK I fixed the Schematic, removed the invalid one (just in case) and here's the latest
PropBasic.zip
