40x4 object attached. (Was:Any objects for the 4004 LCD 40x4?)
I happened accross some 4004 LCD (40x4) units. Does anyone have an object which will work with these?
Edit: Got it! Will upload an object soon.
Jeff
Jeff
Try one of the Hitatchi compatible LCD objects. It may be compatible with this or actually use that chip to run the display........
Ya never know till you try,
FF
Edit: Confirmed, have the upper half of the display working in 4bit mode.
Edit_2: Success. Strobing the second E2 line activates the second half of the display. Re-writing object accordingly.
Edit_3: Nailed it. Cleaning up an object for upload to OBEX soon.
Jeff
I've got a few of these in stock at Propellerpowered.com ($6.50 each)
http://propellerpowered.com/shop/?page_id=707
