Emic 2 tts code needed
I am building a boe bot with the board of eduction shield and Arduino uno . I have the demo code for the EMIC 2 TTS but cannot find any other code to adjust the voice or sound.
Thanks JUSTIN..
Thanks JUSTIN..
The following will set the volume to -20.
The above is written in Spin but I think it should be pretty clear what characters are being set to the Emic 2. The value "13" is a carriage return which if required at the end of each command.
