The cool chips!
I imagine that just about everyone on this forum once in a while comes across an IC (digital/analog/both) that they've never seen before and thinks to themselves "This is cool!" For me, the Propeller is definitely one of them.
What have you come across that you thought was cool?
I knew quad port SRAM is commonly used in the cores of processors, what I did didn't know was that there were manufacturers that made these in external memory form:
http://www.cypress.com/?id=117
It would definitely be cool sitting between four Propellers, or even as an interface between different processors.
If that's a bit excessive, then how about dual-port?
http://www.cypress.com/?id=82
Just imagine what we could do with this! Unfortunately, while hobbyists would use a load of them (if in DIP), I don't really see the commercial quantities for Parallax because of all the other chips out there that would compete.
Lawson
Going down still more levels, some of the least appreciated chips, IMO, but ones which I find quite useful, are three-terminal voltage detectors (also known as "supervisors"). They can be used for much more than just brown-out detectors and power-on reset controllers.
I find the ATTiny84A (SOIC14) and ATTiny87(SOIC20 & TSSOP20) nice pricepoint devices. But yeah, what a pain to setup all those registers.
So much simpler to grab an object and load it into a cog
Well, as a young teenager in the 1971 or so I discovered our local amateur radio club. On my first visit to a meeting there a guy was giving a talk about this new fangled digital logic to all the old HAMs, AND, OR, XOR, counters. adders etc. I was toatally mesmerized and awestruck by the possibilities. The humble SN7400 quad NAND was cool. The SN7490 was incredible. Soon I assembled this calculator http://www.vintagecalculators.com/html/advance_wireless_world.html and get this, ALL the logic was in a single chip! A Texas Instruments TMS1802. Then came the micro-processors, oh my God....
Before those surplus TTL chips became available I played with some RTL parts made by Fairchild, and started building a digital counter using them.
74 series I would get from Henrys Radio on the Edgeware Road. There still seems to be a Henrys their but not much sign of radio.
The Marconi Myriad computer was built in the 1960s using RTL. It used to be popular for air-traffic control.
http://www.youtube.com/watch?v=4IhDMDVBYio
I definitely agree with the 555. The 555 competition that was held a little while back proved this. I was in total awe over some of the "hacks".
Having to build a processor from discrete logic sounds tedious, but definitely cool. One thing that's a bummer is how many good components have become obsolete. While searching online, I've come across many components that would have worked great in a project, but were no longer made and had no equivalents.
@Heater
That calculator is awesome! I particularly enjoy the power supply - no fancy switching wall wart here - just some good ol' fashioned iron, and a few beefy caps
They still command a respectable price on ebay, except for the Chinese knockoffs that can't get the logo correct.
Still have five that need to go on a test bed to check out.
http://forums.parallax.com/showthread.php?142263-IC-Assistance-needed.
Used or replaced almost every chip on the list in some piece of equipment at one time or another.
More recently perhaps one of the transceivers-on-a-chip (nRF24L01+ comes to mind) or direct digital synthesis chips like the AD9912 (1 GHz sample rate, 14bit DAC, upto 400MHz output)
And more recently, the muxing chips from Analog Devices.
...yeah - they are peaking my interest also.
I like the efficiency aspect, which can translate to less heat-sinking requirements. Couple that with a switch-mode power supply and you wind up with lotsa power w/o lotsa weight.
