SumoBot Basic Competition Code
Greetings,
I am new to robotics and recently purchased the SumoBot kit. I've put the project together and it runs perfectly, but I have a couple questions about the code. I'll reference the last program in the book, the Basic Competition Program here to highlight my areas of confusion.
Within this code there is something called the blackThresh which according to the comment sets the threshold for the black reflectivity reading at 1/4 the average of the two sensor readings. However, blackThresh = (lLine / 10) + (rLine / 10). If it was really 1/4 the average shouldn't the variable be set as (lLine / 8) + (rLine / 8)?
Additionally, after this blackThresh is declared and set it is not called later in the code. Therefore, I don't understand why this is included in the program at all since it doesn't seem to have a purpose. Does anyone know why it is included / Am I missing something?
My last question is the order the lineBits and irBits get the left and right sensor data. lbLeft is set to the memory location of lineBits.BIT1 whereas lbRight is set to lineBits.BIT0. irBits shows the same pattern. When interpreting lineBits we see a branch: BRANCH lineBits, [Search_For_Opponent, Spin_Left, Spin_Right, About_Face]. I imagine this to be 00 = Search_For_Opponent; 01 = Spin_Left (since the right sensor hits the line); 10 = Spin_Right (since the left sensor hits the border); 11 = About_Face (since both have hit the border). If I have an array of length two I would address the positions as 0 and 1, where 0 would be on the left. Why then, is lbLeft getting lineBits.BIT1 and lbRight getting lineBits.BIT0? Does memory read right to left? Is there a better way for me to visualize this call? It seems backwards to me, but it works - hence my confusion.
Thank you all for the help. If you have any questions please let me know.
' SumoBot-5.1-Basic-Competition-Program.BS2
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ I/O Definitions ]-------------------------------------------------
LMotor PIN 13 ' left servo motor
RMotor PIN 12 ' right servo motor
LLinePwr PIN 10 ' left line sensor power
LLineIn PIN 9 ' left line sensor input
RLinePwr PIN 7 ' right line sensor power
RLineIn PIN 8 ' right line sensor input
LfIrOut PIN 4 ' left IR LED output
LfIrIn PIN 11 ' left IR sensor input
RtIrOut PIN 15 ' right IR LED output
RtIrIn PIN 14 ' right IR sensor input
Speaker PIN 1 ' piezo speaker
StartLED PIN 0 ' display start delay
' -----[ Constants ]-------------------------------------------------------
LFwdFast CON 1000 ' left motor fwd; fast
LFwdSlow CON 800 ' left motor fwd; slow
LStop CON 750 ' left motor stop
LRevSlow CON 700 ' left motor rev; slow
LRevFast CON 500 ' left motor rev; fast
RFwdFast CON 500 ' right motor fwd; fast
RFwdSlow CON 700 ' right motor fwd; slow
RStop CON 750 ' right motor stop
RRevSlow CON 800 ' right motor rev; slow
RRevFast CON 1000 ' right motor rev; fast
' -----[ Variables ]-------------------------------------------------------
lLine VAR Word ' left sensor raw reading
rLine VAR Word ' right sensor raw reading
blackThresh VAR Word ' QTI black threshold
lineBits VAR Nib ' decoded sensors value
lbLeft VAR lineBits.BIT1
lbRight VAR lineBits.BIT0
irBits VAR Nib ' IR readings (l & r)
irLeft VAR irBits.BIT1
irRight VAR irBits.BIT0
lastIr VAR Nib ' info from last reading
pulses VAR Byte ' counter for motor control
temp VAR Byte
' -----[ EEPROM Data ]-----------------------------------------------------
RunStatus DATA $00 ' run status
' -----[ Initialization ]--------------------------------------------------
Reset:
READ RunStatus, temp ' read current status
temp = ~temp ' invert status
WRITE RunStatus, temp ' save for next reset
IF (temp > 0) THEN END ' okay to run?
' Sets black threshold to 1/4 the average of the two sensor readings.
' SumoBot must be placed over black playing surface before this code runs.
Set_Threshold: ' set QTI black threshold
GOSUB Read_Line_Sensors
LOW LMotor ' make more pins outputs
LOW RMotor
Start_Delay: ' five second delay
FOR temp = 1 TO 5
HIGH StartLED ' show active
PAUSE 900
INPUT StartLED ' blink each second
FREQOUT Speaker, 100, 2500, 3000 ' beep each second
NEXT
GOTO Lunge ' start aggressive!
' -----[ Program Code ]----------------------------------------------------
Main:
' If not on the Shikiri line (border), continue to look for opponent,
' otherwise, spin back toward center and resume search
' --[ Border Avoidance ]--
Spin_Left: ' right sensor was active
FOR pulses = 1 TO 20
PULSOUT LMotor, LRevFast
PULSOUT RMotor, RFwdFast
PAUSE 20
NEXT
lastIr = ' clear scan direction
GOTO Lunge
Spin_Right: ' left sensor was active
PULSOUT LMotor, LFwdFast
PULSOUT RMotor, RRevFast
PAUSE 20
NEXT
lastIr =
GOTO Lunge
About_Face: ' both sensors on Shikiri
FOR pulses = 1 TO 10 ' back up from edge
PAUSE 20
NEXT
FOR pulses = 1 TO 30 ' turn around
PAUSE 20
NEXT
lastIr =
GOTO Lunge
' --[ IR Processing ]--
Search_For_Opponent:
GOSUB Read_IR_Sensors
' If opponent is not in view, scan last known direction. Turn toward
' opponent if seen by one "eye" -- if both, lunge forward
BRANCH irBits, [Scan, Follow_Right, Follow_Left, Lunge]
Scan:
BRANCH lastIR, [Move_Fwd, Scan_Right, Scan_Left]
Move_Fwd:
GOSUB Creep_Forward
GOTO Main
Scan_Right: ' spin right, slow
FOR pulses = 1 TO 5
PULSOUT LMotor, LFwdSlow
PULSOUT RMotor, RRevSlow
PAUSE 20
NEXT
GOSUB Creep_Forward ' keep moving
GOTO Main
Scan_Left: ' spin left, slow
FOR pulses = 1 TO 5
PULSOUT LMotor, LRevSlow
PULSOUT RMotor, RFwdSlow
PAUSE 20
NEXT
GOSUB Creep_Forward
GOTO Main
Follow_Right: ' spin right, fast
lastIR = irBits ' save last direction found
GOTO Main
Follow_Left: ' spin left, fast
lastIR = irBits
GOTO Main
Lunge: ' locked on -- go get him!
FOR pulses = 1 TO 25
IF (lineBits = ) THEN Match_Over ' in sight, we're on the line
NEXT
GOTO Main
' If SumoBot can see the opponent with both "eyes" and both QTIs are
' detecting the border, we must have pushed the opponent out.
Match_Over:
FOR pulses = 1 TO 10 ' stop motors
PULSOUT LMotor, LStop
PULSOUT RMotor, RStop
PAUSE 20
NEXT
INPUT LMotor
INPUT RMotor
FOR temp = 1 TO 10 ' make some noise
HIGH StartLED
INPUT StartLED ' blink LED
PAUSE 100
NEXT
DIRS = $0000 ' disable all outputs
GOTO Reset ' reset for next round
' -----[ Subroutines ]-----------------------------------------------------
Read_Line_Sensors:
HIGH LLinePwr ' activate sensors
HIGH RLinePwr
HIGH LLineIn ' discharge caps
HIGH RLineIn
PAUSE 1
RCTIME LLineIn, 1, lLine ' read left sensor
RCTIME RLineIn, 1, rLine ' read right sensor
LOW LLinePwr ' deactivate sensors
LOW RLinePwr
' convert readings to bits
LOOKDOWN lLine, >=[1000, 0], lbLeft ' 0 = black, 1 = line
LOOKDOWN rLine, >=[1000, 0], lbRight
RETURN
Read_IR_Sensors:
FREQOUT LfIrOut, 1, 38500 ' modulate left IR LED
irLeft = ~LfIrIn ' read input (1 = target)
FREQOUT RtIrOut, 1, 38500 ' modulate right IR LED
irRight = ~RtIrIn ' read input (1 = target)
RETURN
Creep_Forward:
PAUSE 20
NEXT
RETURN
So, with 0 being the right most bit this helps to explain why the right QTI sensor gets lineBits.BIT0 while the left sensor gets lineBits.BIT1. Is this correct?
If anyone has insight on why blackThresh is included in the basic competition program I would appreciate you sharing it. I'm having quite a bit of fun with the robot.
Thanks.
