IC Assistance needed.
So, Several weeks ago I purchased a HUGE assortment of electronics at a garage sale for $10.00. Within this assortment are loads of IC's. Some of them, such as the 555 and 556 timers I know what to do with. However, for the most of them I am unsure as to what they would be good for. Aftr searching the Internet I found a few that are related to the old Asteroids game. I am wondering if there is anyone that can go through the list and make some suggestions as to what I could make with any of them. I am attaching the list. If you can help, let me know if there are any of the IC's you need/want and I will send them out to you.
@erco. Great idea, as soon as I figure out which are are for arcade games I will do that.
So am I to assume the Z80 works the same way as a prop? I found a datasheet archive on the Internet. I am about half way through the list in getting the data sheets. Once that is done I will be able to figure more out. In the mean time, if anyone sees anything of interest let me know.
Edit: I was writing this as the other comments were posted so that answers the question about the prop.
@rwgast_logicdesign, let me know what you are interested in and I am pretty sure we can work something out.
Here's a link to the archive data sheet site: http://www.datasheetarchive.com/
@Circuitsoft, Pick what you want and PM me your address so I can send them to you. As long as there are more than 1 of each type you want. I appreciate the help.
I also have an EEPROM eraser. Since I will most likely never have the time to work with it I may place it in the classifieds, unless the majority of these IC's can be erased with it which I do not know. I will be keeping the timers and items that I can use either in my robotic project or a few other ideas I have. Once I figure that all out I will have post them in the classifieds for trading.
BTW, only the 2716 eproms can be erased, and the cpu chip sounds like basic is preprogrammed in the chip.
If this is what I think it is I put one together once using wire wrap.
I still have it somewhere. It worked with a terminal.
Duane J
Line item 56, RC4151 is a voltage-to-frequency converter I believe.
Thanks for the offer but I have most of those chips already, and most of the others I have no use for. What I meant by "some useful chips there" was that they would be useful for someone learning electronics, logic gates, and analog circuits. The 8 bit ADC and DAC chips would work well with a prop or other micro.
