IC Assistance needed. — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2014-05-16 14:31 in General Discussion
So, Several weeks ago I purchased a HUGE assortment of electronics at a garage sale for $10.00. Within this assortment are loads of IC's. Some of them, such as the 555 and 556 timers I know what to do with. However, for the most of them I am unsure as to what they would be good for. Aftr searching the Internet I found a few that are related to the old Asteroids game. I am wondering if there is anyone that can go through the list and make some suggestions as to what I could make with any of them. I am attaching the list. If you can help, let me know if there are any of the IC's you need/want and I will send them out to you.
    edited 2012-09-06 16:45
    Did you google them all already? Are there data sheets readily available? How do they relate to astroids? Astoids is old enough that it would have been done in 100% hardware, Im intrested to know which of those are specifically for astroids and what there function is. I mean woz built breakout with off the shelf logic gates and other chips to generate the ntsc clock signal. Or do you mean there out of like an atari cartridge lol didnt even think of that :)
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-09-06 16:58
    I did Google some of the chips. I got busy doing other things and really have not had time to get back to it. I can not specifically remember what it was or which IC it was but in reading up on one of them it did mention Asteroids. That popped out as I was an avid player while in Germany in the Military of Asteroids. My wife and I dropped many quarters in to that game, probably enough to have bought one!!!! I plan to do more research but thought if anyone could help out, members of this forum would be a good start. I believe a lot of them are related to older style video games and some have to do with TV's.
    edited 2012-09-06 17:13
    Google vintage arcade game repair to find some repair shops that might buy your chips.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-09-06 17:24
    Here's a start. I'll continue expanding this list as the evening goes on.
    IC                  Common equivalent   Description
    ADC0804LCN          ADC0804             CPU-compatible 8-bit ADC
    SCL4001BE           CD4001B             Quad CMOS NOR Gate
    CD4002AE            CD4002A             Dual CMOS 4-input NOR Gate
    MC14011B            CD4011B             Quad CMOS NAND Gate
    N4012A              CD4012A             Quad CMOS NAND Gate
    SCL4015AE           CD4015A             Dual 4-bit shift register
    CD4017AE            CD4017A             CMOS Decade Counter
    SCL4023AE           CD4023A             Triple 3-input NAND Gate
    4025AE              CD4025A             Triple 3-input NOR Gate
    CD4027BE            CD4027B             Dual CMOS Master/Slave J-K Flip-Flop
    MC14034B            CD4034B             8-stage CMOS Tri-state SERDES
    MC14046B            CD4046B             CMOS Phase-Locked Loop
    SCL4068BE           CD4068B             CMOS 8-input NAND Gate
    CD4069UBE           CD4069B             Hex CMOS Inverter
    4017BE              CD4071B             Quad CMOS OR Gate
    CD4072BE            CD4072B             Quad CMOS OR Gate
    MC14081             CD4081              Quad CMOS AND Gate
    CD4082BCN           CD4082B             Dual CMOS Quad-input AND Gate
    CD4526BCN           CD4526B             4-bit CMOS down counter
    MC14538B            CD4538B             Dual Monostable Multivibrator
    DAC0806LCN          DAC0806             6-bit DAC
    DS1488N             DS1488              Quad RS232-D Line Driver
    DS1489N             DS1489              Quad RS232-D Line Receiver
    DS75150N            DS75150             Dual RS232-C Line Driver
    DS75154N            DS75154             Quad RS232-C Line Receiver
    LM1871N             LM1871              Radio Control Transmitter
    LM1872N             LM1872              Radio Control Receiver
    LM322N              LM322               Timer (vaguely similar to 555)
    LM565CN             LM565               Phase Locked Loop
    LM710CN             LM710               Comparator
    LM723CN             LM723               Adjustable Voltage Regulator
    LM741CN             LM741               Classic common Op-Amp
    LM555CN             NE555               Classic 555 Timer
    TL496CP             TL496               9v Power Supply Controller
    MCM2716C                                2Kx8 UV-Eraseable EPROM
    Z8671                                   Z8 Micro with BASIC in Mask ROM
    RC4151M             μA4151              Voltage to Frequency Converter
    MM74C00N            74C00               Quad CMOS NAND Gate
    MM74C08N            74C08               Quad CMOS AND Gate
    MM74C73N            74C73               Dual CMOS J-K Flip-Flops
    DM74LS02N           74LS02              Quad Low-Power Schottky NOR Gate
    DM74LS04N           74LS04              Hex Low-Power Schottky Inverter
    74LS08DC            74LS08              Quad Low-Power Schottky AND Gate
    SN74LS21N           74LS21              Dual Low-Power Schottky 4-input AND Gate
    SN74LS32N           74LS32              Quad Low-Power Schottky OR Gate
    DM74LS86N           74LS86              Quad Low-Power Schottky XOR Gate
    DM74LS93N           74LS93              Low-Power Schottky 4-bit binary counter
    SN74LS122N          74LS122N            Low-Power Schottky Monostable Multivibrator
    74LS133PC           74LS133             Low-Power Schottky 13-input NAND Gate
    MB74LS136           74LS136             Quad Low-Power Schottky XOR Gate, Open-Collector
    SN74LS138N          74LS138             Low-Power Schottky 3-to-8 line decoder/demultiplexer
    SN74LS148N          74LS148             Low-Power Schottky 8-to-3 line priority encoder
    DM74LS164N          74LS164             Low-Power Schottky 8-bit Deserializer/Shift Register
    SN74LS166N          74LS166             Low-Power Schottky 8-bit Serializder/Shift Register
    DM74LS168N          74LS168N            Low-Power Schottky 4-bit BCD Decade Counter
    SN74LS174N          74LS174N            Hex Low-Power Schottky D Flip-Flop
    SN74196N            74LS196             Low-Power Schottky 4-state Ripple Counter
    74LS244PC           74LS244             Dual Low-Power Schottky 4-bit buffer with enable
    SN74LS245N          74LS245             Low-Power Schottky 8-bit bus driver
    74LS260N            74LS260N            Dual Low-Power Schottky 5-input NOR Gate
    DM74LS279N          74LS279             Quad Low-Power Schottky SR Latch
    74LS373N            74LS373             Octal Low-Power Schottky D-Type Transparent Latch
    LM307N              307                 Op-Amp
    7402N               7402                Quad TTL NOR Gate
    DM7402N             7402                Quad TTL NOR Gate
    DM7405N             7405                Hex TTL Inverter
    SW7486-N            7486                Quad TTL XOR Gate
    SW74121N            74121               Monostable Multivibrator
    edited 2012-09-06 18:03
    @Circuitsoft, Thanks for this info. Any suggestions as to what to use them on?
    @erco. Great idea, as soon as I figure out which are are for arcade games I will do that.
    edited 2012-09-06 18:26
    z8671 Thats pretty sweet id download the data sheet and see what its all about, you mentioned you dont have a prop well you have a z80 micro controller :). I went to zilogs site a while back and couldnt find any of there micros in dip cases
    edited 2012-09-06 18:35
    Note, it's not a z80, it is a z8 which is a very different architecture, though it has a similar instruction set.
    edited 2012-09-06 18:43
    Symantics.... lol. Sorry for that, a Zilog z80 is an old micro processor while as the chip you have is Zilog micro controller, like circuitsoft said similar intructions to a z80 cpu, these were use in Sinclair, Altair, and trs80 to name a few. Anyways like I said if its a dip thats a pretty good find if you decide your not into it maybe we can work something out after I pa-ruse the data sheet
    edited 2012-09-06 19:05
    z8671 you mentioned you dont have a prop well you have a z80 micro controller :). I went to zilogs site a while back and couldnt find any of there micros in dip cases
    So am I to assume the Z80 works the same way as a prop? I found a datasheet archive on the Internet. I am about half way through the list in getting the data sheets. Once that is done I will be able to figure more out. In the mean time, if anyone sees anything of interest let me know.
    Edit: I was writing this as the other comments were posted so that answers the question about the prop.
    @rwgast_logicdesign, let me know what you are interested in and I am pretty sure we can work something out.
    Here's a link to the archive data sheet site: http://www.datasheetarchive.com/
    @Circuitsoft, Pick what you want and PM me your address so I can send them to you. As long as there are more than 1 of each type you want. I appreciate the help.
    I also have an EEPROM eraser. Since I will most likely never have the time to work with it I may place it in the classifieds, unless the majority of these IC's can be erased with it which I do not know. I will be keeping the timers and items that I can use either in my robotic project or a few other ideas I have. Once I figure that all out I will have post them in the classifieds for trading.
    edited 2012-09-06 19:42
    Here is the list sorted by category. There are some useful chips there.
    BTW, only the 2716 eproms can be erased, and the cpu chip sounds like basic is preprogrammed in the chip.
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-09-06 19:57
    I think the Z8671 contains a version of TinyBasic in ROM.
    If this is what I think it is I put one together once using wire wrap.
    I still have it somewhere. It worked with a terminal.
    Duane J
    edited 2012-09-06 20:05
    kwinn wrote: »
    Great. Thanks for this. PM me your address and a list of what you would like and how many and as long as I have more than 1 I will send out to you. I know the 555's will come in handy. Which other ones do you consider "useful"?
    edited 2012-09-06 21:11
    kwinn wrote: »
    Line item 56, RC4151 is a voltage-to-frequency converter I believe.
    edited 2012-09-06 21:23
    I updated my previous post, so it's complete now.
    edited 2012-09-06 22:34
    NWCCTV, I shot you a PM, didnt wanna throw the thread off to bad or air some personal business to the world :)
    edited 2012-09-06 23:33
    NWCCTV wrote: »
    Thanks for the offer but I have most of those chips already, and most of the others I have no use for. What I meant by "some useful chips there" was that they would be useful for someone learning electronics, logic gates, and analog circuits. The 8 bit ADC and DAC chips would work well with a prop or other micro.
    edited 2012-09-07 05:43
    The Z8 is quite different to the Z80 instruction set.
  • annielanniel Posts: 1
    Would you still have one of those Z8671 chips?
