High current load to prop
I have a problem that I have been working on for awhile now. I am hoping that
you guys(gals) can help.
I need to control 16, 9 volt, 100mA filament lamps in a scanner type situation (back and forth).
A couple restrictions..
Max output per I/O at 15mA. (up to 4 I/O on at same time)
PCB space is limited (1.25" x 3.0" (3.175cm x 7.62cm))
I have tried several transistors, arrays, buffers, mosfets, I had thoughts about opto-couplers, but cant find any 8 channel. in order to get the required number it wont fit in the required space.
thanks
stilgar
thanks
stilgar
thanks
How many of these lamps need independent control ?
Are you switching a 9.1V regulated supply ?
This device has lower drop than the older darlington variant
http://www.ti.com/product/uln2003v12
or the TIPIC6A/B/C/259/595/596 series save pins.
ground to ground, inputs to microcontroller, outputs to bulbs, other side of bulbs to +9V. You will lose some brightness due to the darlingtons.
Are these serious batteries, or the jellybean PP9 ? - How long do you expect them to last ?
For independent control, the serial Power MOS devices in the TIPIC6A/B/C/259/595/596 series, let you choose Current/Price and they have low losses, and use few host pins.
Check your lamp peak current, with a new battery.
I think you mean PP3, PP9's are quite large (they would not be nice to drop on your toes!). PP6's are intermediate in size.
BTW, 100ma is NOT high current
Oops, yes, the PP3, I try to avoid them like the plague, so am rusty on the exact name..
I have seen long life Lithium batteries claiming 1200mAH in a PP3 case... but they are not cheap.
At standard operating temperatures (around 2500K) tungsten filaments will have about 12 to 14 times the resistance they have when at room temperature - thus the inrush current when switching on from cold will be about 12 to 14 times the steady-state operating current. So for a 100mA bulb that implies 1.2 to 1.4A at switch on (briefly).
The TPIC6595 has a pulsed current maximum rating of 1.5A. That's rather close for comfort, I'd change the wording to "can just handle the current" rather than "easily handle the current". Also you might need to consider decoupling capacitors as switching many bulbs simultaneously will mean large current spikes that those batteries might fail to provide, depending on the internal resistance.
For a high-temperature bulb such as tungsten-halogen, the ratio from hot to cold might be more like 20 - see the table on this page: http://hypertextbook.com/facts/2004/DeannaStewart.shtml
All good points to consider. The peak current is is very brief, is reduced by the internal resistance of the output transistors, and can be reduced further by adding a small inductor in series. I have used the TPIC for driving a bulb filament (12V 0.1A) in the past and the only time one failed was when the bulb burned out.
