How to manipulate value in Dat section
In a DAT area, the following are listed, they represent bitmaps for the numbers 1 through 0 and are used on an LCD screen similar to a VGA display. I cannot just print the numbers using PRINT(x), since the LCD is flipped on edge 90 degrees. So I flipped the numbers and made new bitmaps, exported as .dat.
The program is out of memory using BST optimized and deleting unused. There is more work to be done so I am looking to cut the memory wherever possible. One area is below, where I need to display 4 digits across the LCD using bitmaps. All I could come up with was to use the same .dat files and just place them at different spacings along the Y. So if the number is 1234, the 1 is at y=14, the 2 is at y=10, etc. This is wasting space in DAT. So the question is, how can I call up these graphics_info bytes and modify the y number and therefore use only one section versus 4 copies?
Next question is, what options exist to park a lot of bitmaps that are called up as needed? SD card? And, can the SD card be accessed to read a la carte dat files?
Can these graphics_info bytes be move to VAR, and I could just simply modify them on the fly prior to each use? If so, I would appreciate an example of how these bytes would be translated to VAR.
Thanks.
Thanks.
'''password enter char 1 graphics61_info byte 1, 2, 4, 28, 14, 0 '1 graphics62_info byte 1, 2, 4, 28, 14, 0 '2 graphics63_info byte 1, 2, 4, 28, 14, 0 '3 graphics64_info byte 1, 2, 4, 28, 14, 0 '4 graphics65_info byte 1, 2, 4, 28, 14, 0 '5 graphics66_info byte 1, 2, 4, 28, 14, 0 '6 graphics67_info byte 1, 2, 4, 28, 14, 0 '7 graphics68_info byte 1, 2, 4, 28, 14, 0 '8 graphics69_info byte 1, 2, 4, 28, 14, 0 '9 graphics70_info byte 1, 2, 4, 28, 14, 0 '0 '''password enter char 2 graphics71_info byte 1, 2, 4, 28, 10, 0 '1 graphics72_info byte 1, 2, 4, 28, 10, 0 '2 graphics73_info byte 1, 2, 4, 28, 10, 0 '3 graphics74_info byte 1, 2, 4, 28, 10, 0 '4 graphics75_info byte 1, 2, 4, 28, 10, 0 '5 graphics76_info byte 1, 2, 4, 28, 10, 0 '6 graphics77_info byte 1, 2, 4, 28, 10, 0 '7 graphics78_info byte 1, 2, 4, 28, 10, 0 '8 graphics79_info byte 1, 2, 4, 28, 10, 0 '9 graphics80_info byte 1, 2, 4, 28, 10, 0 '0 '''password enter char 3 graphics81_info byte 1, 2, 4, 28, 6, 0 '1 graphics82_info byte 1, 2, 4, 28, 6, 0 '2 graphics83_info byte 1, 2, 4, 28, 6, 0 '3 graphics84_info byte 1, 2, 4, 28, 6, 0 '4 graphics85_info byte 1, 2, 4, 28, 6, 0 '5 graphics86_info byte 1, 2, 4, 28, 6, 0 '6 graphics87_info byte 1, 2, 4, 28, 6, 0 '7 graphics88_info byte 1, 2, 4, 28, 6, 0 '8 graphics89_info byte 1, 2, 4, 28, 6, 0 '9 graphics90_info byte 1, 2, 4, 28, 6, 0 '0 '''password enter char 4 graphics91_info byte 1, 2, 4, 28, 2, 0 '1 graphics92_info byte 1, 2, 4, 28, 2, 0 '2 graphics93_info byte 1, 2, 4, 28, 2, 0 '3 graphics94_info byte 1, 2, 4, 28, 2, 0 '4 graphics95_info byte 1, 2, 4, 28, 2, 0 '5 graphics96_info byte 1, 2, 4, 28, 2, 0 '6 graphics97_info byte 1, 2, 4, 28, 2, 0 '7 graphics98_info byte 1, 2, 4, 28, 2, 0 '8 graphics99_info byte 1, 2, 4, 28, 2, 0 '9 graphics100_info byte 1, 2, 4, 28, 2, 0 '0
PUB Configdata(b) byte[@graphics61_info][4] := b byte[@graphics62_info][4] := b byte[@graphics63_info][4] := b byte[@graphics64_info][4] := b byte[@graphics65_info][4] := b byte[@graphics66_info][4] := b byte[@graphics67_info][4] := b byte[@graphics68_info][4] := b byte[@graphics69_info][4] := b byte[@graphics70_info][4] := b PUB PW1(g, bbb) '(number to display, offset in dat) Configdata(bbb) case g 1 : DrawBitmap(@graphic1_data, @graphics61_info) 2 : DrawBitmap(@graphic2_data, @graphics62_info) 3 : DrawBitmap(@graphic3_data, @graphics62_info) 4 : DrawBitmap(@graphic4_data, @graphics64_info) 5 : DrawBitmap(@graphic5_data, @graphics65_info) 6 : DrawBitmap(@graphic6_data, @graphics66_info) 7 : DrawBitmap(@graphic7_data, @graphics67_info) 8 : DrawBitmap(@graphic8_data, @graphics68_info) 9 : DrawBitmap(@graphic9_data, @graphics69_info) 0 : DrawBitmap(@graphic0_data, @graphics70_info)This is what I have come up with so far in terms of modifying the dat section.
