Wall Following Robots
My first test was a little shaky:
But then I saw this related video of someone's kit and I felt pretty good! http://www.youtube.com/watch?feature=player_detailpage&v=abncTBjWpk8#t=72s
I started pecking away at this seemingly simple task, thinking it would be easy with the S2 and Phils super cool Ping((( holder.
Had to wrap a bit of tape to the bottom of the Ping((( holder, so as to raise it above the wheel when it's pointed to the side.
No big deal, it only needed to raise about 3/8". So now I am able to make some progress with the code.(well, what I call code...)
My S2 can follow a wall fairly well, as long as the wall doesn't end, or have a corner...
I hope Whits crew can step and try this out, It is an excellent learning oppertunity...
Anyways, thanks again for posting erco. :thumb::thumb:
Let's see some video!
Endless walls? Exactly how big is your house, Mr. Contractor?
By the way, one of the first robots ever was a bit Shakey...http://en.wikipedia.org/wiki/Shakey_the_robot
You know a PING sensor would interface without any issues to a Scribbler 1.
I'll get around to it unless someone beats me to it. Long live old blue!
I think I like the your behavior, it does look very parallel. It just keeps a consistent distance to the wall with the IR, right?
Bounce video
[video=youtube_share;xkYpWYhpIis]
Parallel video
[video=youtube_share;AQK6b2CNTrg]
Complete thread:
http://forums.parallax.com/showthread.php?139096-Wall-Following-Examples-(video-and-code)
http://letsmakerobots.com/node/696
Indeed, I've been contemplating using the Ping))) turret to alternately read forwards and to the side. Basically multiplexing the sensor because you can estimate from the last reading the amount of forwards and sideways leeway you have. So you don't need to constantly read both directions.
Those cars are neat and really move compared with servos.
