Power Supply for QuickStart
blittled
I was looking into powering a QuickStart through a USB charger rather than the computer. I found one at Radio Shack that has 2 outputs http://www.radioshack.com/product/index.jsp?productId=4439416#tabsetBasic . One is 5 V 500mA and the other is 5V 1 Amp. Would this work?
But I have to add that I have had terrible luck with enercell power supplies from Radio Shack. Current and voltage do not seem to be as close to the intended values as other supplies. I had one 5v supply that started producing a mysterious buzz when more current was used, and another 12 v that just died spontaneously. I won't buy these anymore.
Actually, I generally avoid Radio Shack all together. They don't even the right parts for their own equipment. Nobody in the store knows anything about electronics, and anytime I want to buy something a simple a single resistor I still have to wait forever because somebody is getting their cellphone set up.
I think I am going to start recommending something like this to my friends.
http://www.gadgetgangster.com/find-a-project/56.html?projectnum=408
This way you only have one USB cable for power and programming. I think less cables will appeal to people.
@Mike I found out the add on board I'm using already has the /USB_PWR_EN grounded so that is no problem.
@Varnon I have 2 300ma 3.5-12V and one 1 Amp 3.5V-12V Enercells and the only problem I had was I found they are not tightly regulated since I burned out a serial LCD in one week with one once since the ripple went beyond the LCD's max voltage input. If these 5V chargers are regulated I have no problem buying one.
They are regulated at 5V with 1A currents on some.
Duane J
