Program won't run from EEPROM but will from RAM
Hi,
I am using FullDuplexSerial4portPlus_0v3 and can not get the program to run when loaded from eeprom. It works fine when I reload from RAM. I can not seem to find the problem. Has anyone experienced this before?
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 DIRECTION = 0 PULSE = 1 ENABLE = 2 ENCODER = 1 MINSPEED = 20 MAXSPEED = 4500 MINACCEL = 1 MAXACCEL = 20 stepsPerRev = 200 numMOTORS = 2 motorArraySIZE = 9 'motor array elements arrayPOSITION = 0 arrayWORLD = 1 arrayOFFSET = 2 arraySPEED = 3 arrayACCEL = 4 arrayPULSE = 5 arrayENCODER = 6 arrayFREQ = 7 arrayTARGET = 8 VAR long motor, position, world, offset, speed, accel, pulsePin, encoderPin, freq long directionPin, disablePin long motorData[numMOTORS * motorArraySIZE] ' Motor registers loaded into motor object. byte char[4] OBJ stepper : "stepper_clocks" cmd : "FullDuplexSerial4portPlus_0v3" PUB main | index, curSpeed, xPos, yPos cmd.Init cmd.AddPort(0,31,30,-1,-1,0,0,115200) cmd.Start waitcnt(clkfreq/2 + cnt) cmd.rxflush(0) dira[5..0]~~ ' initialize HUB memory with motor data repeat motor from 1 to numMOTORS index := motor - 1 motorData[index * motorArraySIZE + arrayPOSITION ] := 0 motorData[index * motorArraySIZE + arrayWORLD] := 0 motorData[index * motorArraySIZE + arrayOFFSET] := 0 motorData[index * motorArraySIZE + arraySPEED] := MINSPEED motorData[index * motorArraySIZE + arrayACCEL] := MINACCEL motorData[index * motorArraySIZE + arrayPULSE] := PULSE + (index * 3) ' 3 pins need to be contiguous (direction, pulse, disable) motorData[index * motorArraySIZE + arrayENCODER] := ENCODER + (index * 3)' only one encoder pin is used motorData[index * motorArraySIZE + arrayFREQ] := 1 ' 1 puts stepper in hold at cogstart only motorData[index * motorArraySIZE + arrayTARGET] := 0 ' set initil position target equal to zero stepper.start(motor, @motorData) ' set up 1 cog for each motor with 2 counters (ctra & ctrb); cog ctra: APIN = PULSE; cog ctrb: APIN = ENCODER waitcnt(clkfreq/2 + cnt) freq := 60 * clkfreq / 200 / 2 / MINSPEED ' ctr freq = clkfreq (pulses per sec) / steps per revolution / 10 microsteps per step / pulses per microstep / revs per sec repeat motor from 1 to numMOTORS stepper.set_period(motor, freq, freq) ' set the period for ctra module (motor pulse rate) waitcnt(clkfreq/2 + cnt) repeat motor from 1 to numMOTORS offMotor(motor) forwardMotor(motor) homeMotor(motor) waitcnt(clkfreq/2 + cnt) '===============================Motor Commands=================================== ' ' s = motor set speed ' i = motor move incremental ' a = motor set acceleration ' o = motor on ' k = motor off ' b = motor backward ' f = motor forward ' h = hold motor ' r = release motor ' s, p and a commands ask for values repeat char[0] := cmd.rx(0) char[1] := cmd.rx(0) cmd.tx(0,$0D) motor := char[1] - $30 case char[0] "s": cmd.Str(0, String("Current speed: ")) curSpeed := motorData[(motor-1) * motorArraySIZE + arraySPEED ] cmd.dec(0, curSpeed) cmd.tx(0, $0D) cmd.Str(0, String("New speed (20 < rpm < 4500): ")) speed := getVal if IsOn(motor) == 1 rampSpeed(motor, curSpeed, Speed) else setSpeed(motor, Speed) "i": cmd.Str(0, String("Current position: ")) cmd.dec(0, getPosition(motor)) cmd.tx(0, $0D) cmd.str(0, string("Incremental steps: ")) position := getVal positionMotor(motor, position) cmd.Str(0, String("Final position: ")) cmd.dec(0, getPosition(motor)) cmd.tx(0, $0D) "a": cmd.Str(0, String("Current acceleration: ")) accel := motorData[(motor-1) * motorArraySIZE + arrayACCEL] cmd.dec(0, accel) cmd.Str(0, String($0D, "New acceleration: ")) accel := getVal setAccel(motor, accel) "o": onMotor(motor) "k": offMotor(motor) "b": reverseMotor(motor) "f": forwardMotor(motor) "h": homeMotor(motor) "r": releaseMotor(motor) "z": zeroMotor(motor) "g": getPosition(motor) "m": cmd.Str(0, String("Current position: X= ")) cmd.dec(0, getPosition(1)) cmd.Str(0, String(" Y = ")) cmd.dec(0, getPosition(2)) cmd.tx(0, $0D) cmd.Str(0, String("Delta X: ")) xPos := getVal cmd.Str(0, String("Delta Y: ")) yPos := getVal moveXY(xPos, yPos) cmd.Str(0, String("Final position: X= ")) cmd.dec(0, getPosition(1)) cmd.Str(0, String(" Y = ")) cmd.dec(0, getPosition(2)) cmd.tx(0, $0D) '////////////////// Motion Programs //////////////////////// PRI getVal: num | digit, sign num := 0 sign := 1 repeat while (digit := cmd.rx(0)) <> $0D if digit == "-" sign := -1 next else if digit < $30 or digit > $39 num := 0 quit num := (num * 10 + (digit - $30)) num := sign * num PRI rampSpeed(motorNum, beginSpeed, endSpeed) | ramp, rampDelay accel := motorData[(motorNum-1) * motorArraySIZE + arrayACCEL] repeat ramp from beginSpeed to endSpeed step accel setSpeed(motorNum, ramp) PRI setSpeed(motorNum, newSpeed) newSpeed #>= MINSPEED newSpeed <#= MAXSPEED motorData[(motor-1) * motorArraySIZE + arraySPEED] := newSpeed freq := 60 * clkfreq / 200 / 2 / newSpeed ' ctr freq = clkfreq (pulses per sec) / steps per revolution / 10 microsteps per step / pulses per microstep / revs per sec stepper.set_period(motor, freq, freq) PRI setAccel(motorNum, newAccel) newAccel #>= MINACCEL newAccel <#= MAXACCEL motorData[(motorNum-1) * motorArraySIZE + arrayACCEL] := newAccel PRI holdMotor(motorNum) disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 stepper.set_period(motorNum, 0, 0) outa[disablePin]~~ PRI releaseMotor(motorNum) disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 outa[disablePin]~ PRI onMotor(motorNum) | curSpeed curSpeed := motorData[(motorNum-1) * motorArraySIZE + arraySPEED] setSpeed(motorNum, MINSPEED) disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 outa[disablePin]~~ rampSpeed(motorNum, MINSPEED , curSpeed) PRI offMotor(motorNum) | curSpeed curSpeed := motorData[(motorNum-1) * motorArraySIZE + arraySPEED] disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 rampSpeed(motorNum, curSpeed, MINSPEED) outa[disablePin]~ setSpeed(motorNum, curSpeed) outa[disablePin]~ PRI isOn(motorNum) disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 return ina[disablePin] PRI reverseMotor(motorNum) | curSpeed disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 directionPin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] - 1 curSpeed := motorData[(motorNum-1) * motorArraySIZE + arraySPEED] if IsOn(motorNum) == 0 outa[directionPin]~~ else rampSpeed(motorNum, curSpeed, MINSPEED) outa[direction]~~ rampSpeed(motorNum, MINSPEED, curSpeed) PRI forwardMotor(motorNum) | curSpeed disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 directionPin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] - 1 curSpeed := motorData[(motorNum-1) * motorArraySIZE + arraySPEED] if IsOn(motorNum) == 0 outa[directionPin]~ else rampSpeed(motorNum, curSpeed, MINSPEED) outa[directionPin]~ rampSpeed(motorNum, MINSPEED, curSpeed) PRI getPosition(motorNum) position := motorData[(motorNum-1) * motorArraySIZE + arrayPOSITION] world := motorData[(motorNum-1) * motorArraySIZE + arrayWORLD] offset := motorData[(motorNum-1) * motorArraySIZE + arrayOFFSET] return world - offset PRI zeroMotor(motorNum) | worldPtr, offsetPtr worldPtr := @motorData[(motorNum-1) * motorArraySIZE + arrayWORLD] offsetPtr := @motorData[(motorNum-1) * motorArraySIZE + arrayOFFSET] long[offsetPtr] := long[worldPtr] PRI homeMotor(motorNum) | worldPtr, offsetPtr worldPtr := @motorData[(motorNum-1) * motorArraySIZE + arrayWORLD] offsetPtr := @motorData[(motorNum-1) * motorArraySIZE + arrayOFFSET] long[offsetPtr] := long[worldPtr] := 0 PRI positionMotor(motorNum, newPos) | posPtr, curSpeed, curAccel disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1 directionPin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] - 1 curSpeed := motorData[(motorNum-1) * motorArraySIZE + arraySPEED] curAccel := motorData[(motorNum-1) * motorArraySIZE + arrayACCEL] posPtr := @motorData[(motorNum-1) * motorArraySIZE+ arrayPOSITION] if newPos < 0 reverseMotor(motorNum) newPos := -newPos else forwardMotor(motorNum) if newPos < 2000 setSpeed(motorNum, MINSPEED) setAccel(motorNum, MINACCEL) onMotor(motorNum) repeat while long[posPtr] < (newPos - 2000) setAccel(motorNum, MAXACCEL) rampSpeed(motorNum, speed, MINSPEED) repeat while long[posPtr] < newPos offMotor(motorNum) setSpeed(motorNum, curSpeed) setAccel(motornum, curAccel) PRI moveXY(x1, y1) | posXptr, posYptr, motor1, motor2, curSpeed1, curSpeed2, accel1, accel2 motor1 := 1 motor2 := 2 posXptr := @motorData[(motor1-1) * motorArraySIZE+ arrayPOSITION] posYptr := @motorData[(motor2-1) * motorArraySIZE+ arrayPOSITION] if x1 < 0 reverseMotor(motor1) x1 := -x1 else forwardMotor(motor1) if y1 < 0 reverseMotor(motor2) y1 := -y1 else forwardMotor(motor2) onMotor(motor1) onMotor (motor2) repeat if long[posXptr] > (x1 - 2000) curSpeed1 := motorData[(motor1-1) * motorArraySIZE + arraySPEED] rampSpeed(motor1, curSpeed1, MINSPEED) if long[posYptr] < (y1 - 2000) curSpeed2 := motorData[(motor2-1) * motorArraySIZE + arraySPEED] rampSpeed(motor1, curSpeed2, MINSPEED) if long[posXptr] > x1 offMotor(motor1) if long[posYptr] > y1 offMotor(motor2) if (isOn(motor1) == 0) AND (isOn(motor2) == 0) quit setSpeed(motor1, curSpeed1) setSpeed(motor2, curSpeed2)
Exactly what behavior are you seeing? Perhaps the program is affected by a power cycle and you're not power cycling when you download the program into RAM to run, but you might be power cycling when you download and run the program from EEPROM.
I am using SimpleIDE to load programs. If I load to to EEPROM the program will not execute. When I load to RAM it runs. Is this just normal behavior?
I've not had problems with SimpleIDE on a Mac.
The funny thing is I do not recall this behavior from SimpleIDE in the past. I presumed I had somehow implemented a memory usage scheme that became problematic with the enhanced SerialDriver4port object.
