Program won't run from EEPROM but will from RAM
Hi,
I am using FullDuplexSerial4portPlus_0v3 and can not get the program to run when loaded from eeprom. It works fine when I reload from RAM. I can not seem to find the problem. Has anyone experienced this before?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
DIRECTION = 0
PULSE = 1
ENABLE = 2
ENCODER = 1
MINSPEED = 20
MAXSPEED = 4500
MINACCEL = 1
MAXACCEL = 20
stepsPerRev = 200
numMOTORS = 2
motorArraySIZE = 9
'motor array elements
arrayPOSITION = 0
arrayWORLD = 1
arrayOFFSET = 2
arraySPEED = 3
arrayACCEL = 4
arrayPULSE = 5
arrayENCODER = 6
arrayFREQ = 7
arrayTARGET = 8
VAR
long motor, position, world, offset, speed, accel, pulsePin, encoderPin, freq
long directionPin, disablePin
long motorData[numMOTORS * motorArraySIZE] ' Motor registers loaded into motor object.
byte char[4]
OBJ
stepper : "stepper_clocks"
cmd : "FullDuplexSerial4portPlus_0v3"
PUB main | index, curSpeed, xPos, yPos
cmd.Init
cmd.AddPort(0,31,30,-1,-1,0,0,115200)
cmd.Start
waitcnt(clkfreq/2 + cnt)
cmd.rxflush(0)
dira[5..0]~~
' initialize HUB memory with motor data
repeat motor from 1 to numMOTORS
index := motor - 1
motorData[index * motorArraySIZE + arrayPOSITION ] := 0
motorData[index * motorArraySIZE + arrayWORLD] := 0
motorData[index * motorArraySIZE + arrayOFFSET] := 0
motorData[index * motorArraySIZE + arraySPEED] := MINSPEED
motorData[index * motorArraySIZE + arrayACCEL] := MINACCEL
motorData[index * motorArraySIZE + arrayPULSE] := PULSE + (index * 3) ' 3 pins need to be contiguous (direction, pulse, disable)
motorData[index * motorArraySIZE + arrayENCODER] := ENCODER + (index * 3)' only one encoder pin is used
motorData[index * motorArraySIZE + arrayFREQ] := 1 ' 1 puts stepper in hold at cogstart only
motorData[index * motorArraySIZE + arrayTARGET] := 0 ' set initil position target equal to zero
stepper.start(motor, @motorData) ' set up 1 cog for each motor with 2 counters (ctra & ctrb); cog ctra: APIN = PULSE; cog ctrb: APIN = ENCODER
freq := 60 * clkfreq / 200 / 2 / MINSPEED ' ctr freq = clkfreq (pulses per sec) / steps per revolution / 10 microsteps per step / pulses per microstep / revs per sec
stepper.set_period(motor, freq, freq) ' set the period for ctra module (motor pulse rate)
offMotor(motor)
forwardMotor(motor)
homeMotor(motor)
'===============================Motor Commands===================================
' s = motor set speed
' i = motor move incremental
' a = motor set acceleration
' o = motor on
' k = motor off
' b = motor backward
' f = motor forward
' h = hold motor
' r = release motor
' s, p and a commands ask for values
repeat
char[0] := cmd.rx(0)
char[1] := cmd.rx(0)
cmd.tx(0,$0D)
motor := char[1] - $30
case char[0]
"s":
cmd.Str(0, String("Current speed: "))
curSpeed := motorData[(motor-1) * motorArraySIZE + arraySPEED ]
cmd.dec(0, curSpeed)
cmd.tx(0, $0D)
cmd.Str(0, String("New speed (20 < rpm < 4500): "))
speed := getVal
if IsOn(motor) == 1
rampSpeed(motor, curSpeed, Speed)
else
setSpeed(motor, Speed)
"i":
cmd.Str(0, String("Current position: "))
cmd.dec(0, getPosition(motor))
cmd.tx(0, $0D)
cmd.str(0, string("Incremental steps: "))
position := getVal
positionMotor(motor, position)
cmd.Str(0, String("Final position: "))
cmd.tx(0, $0D)
"a":
cmd.Str(0, String("Current acceleration: "))
accel := motorData[(motor-1) * motorArraySIZE + arrayACCEL]
cmd.dec(0, accel)
cmd.Str(0, String($0D, "New acceleration: "))
accel := getVal
setAccel(motor, accel)
"o":
onMotor(motor)
"k":
offMotor(motor)
"b":
reverseMotor(motor)
"f":
forwardMotor(motor)
"h":
homeMotor(motor)
"r":
releaseMotor(motor)
"z":
zeroMotor(motor)
"g":
getPosition(motor)
"m":
cmd.Str(0, String("Current position: X= "))
cmd.dec(0, getPosition(1))
cmd.Str(0, String(" Y = "))
cmd.dec(0, getPosition(2))
cmd.tx(0, $0D)
cmd.Str(0, String("Delta X: "))
xPos := getVal
cmd.Str(0, String("Delta Y: "))
yPos := getVal
moveXY(xPos, yPos)
cmd.Str(0, String("Final position: X= "))
cmd.tx(0, $0D)
'////////////////// Motion Programs ////////////////////////
PRI getVal: num | digit, sign
num := 0
sign := 1
repeat while (digit := cmd.rx(0)) <> $0D
if digit == "-"
sign := -1
next
else
if digit < $30 or digit > $39
num := 0
quit
num := (num * 10 + (digit - $30))
num := sign * num
PRI rampSpeed(motorNum, beginSpeed, endSpeed) | ramp, rampDelay
accel := motorData[(motorNum-1) * motorArraySIZE + arrayACCEL]
repeat ramp from beginSpeed to endSpeed step accel
setSpeed(motorNum, ramp)
PRI setSpeed(motorNum, newSpeed)
newSpeed #>= MINSPEED
newSpeed <#= MAXSPEED
motorData[(motor-1) * motorArraySIZE + arraySPEED] := newSpeed
freq := 60 * clkfreq / 200 / 2 / newSpeed ' ctr freq = clkfreq (pulses per sec) / steps per revolution / 10 microsteps per step / pulses per microstep / revs per sec
PRI setAccel(motorNum, newAccel)
newAccel #>= MINACCEL
newAccel <#= MAXACCEL
motorData[(motorNum-1) * motorArraySIZE + arrayACCEL] := newAccel
PRI holdMotor(motorNum)
disablePin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] + 1
stepper.set_period(motorNum, 0, 0)
outa[disablePin]~~
PRI releaseMotor(motorNum)
outa[disablePin]~
PRI onMotor(motorNum) | curSpeed
curSpeed := motorData[(motorNum-1) * motorArraySIZE + arraySPEED]
setSpeed(motorNum, MINSPEED)
outa[disablePin]~~
rampSpeed(motorNum, MINSPEED , curSpeed)
PRI offMotor(motorNum) | curSpeed
rampSpeed(motorNum, curSpeed, MINSPEED)
outa[disablePin]~
setSpeed(motorNum, curSpeed)
outa[disablePin]~
PRI isOn(motorNum)
return ina[disablePin]
PRI reverseMotor(motorNum) | curSpeed
directionPin := motorData[(motorNum-1) * motorArraySIZE + arrayPULSE] - 1
if IsOn(motorNum) == 0
outa[directionPin]~~
else
outa[direction]~~
rampSpeed(motorNum, MINSPEED, curSpeed)
PRI forwardMotor(motorNum) | curSpeed
outa[directionPin]~
else
outa[directionPin]~
PRI getPosition(motorNum)
position := motorData[(motorNum-1) * motorArraySIZE + arrayPOSITION]
world := motorData[(motorNum-1) * motorArraySIZE + arrayWORLD]
offset := motorData[(motorNum-1) * motorArraySIZE + arrayOFFSET]
return world - offset
PRI zeroMotor(motorNum) | worldPtr, offsetPtr
worldPtr := @motorData[(motorNum-1) * motorArraySIZE + arrayWORLD]
offsetPtr := @motorData[(motorNum-1) * motorArraySIZE + arrayOFFSET]
long[offsetPtr] := long[worldPtr]
PRI homeMotor(motorNum) | worldPtr, offsetPtr
long[offsetPtr] := long[worldPtr] := 0
PRI positionMotor(motorNum, newPos) | posPtr, curSpeed, curAccel
curAccel := motorData[(motorNum-1) * motorArraySIZE + arrayACCEL]
posPtr := @motorData[(motorNum-1) * motorArraySIZE+ arrayPOSITION]
if newPos < 0
newPos := -newPos
else
if newPos < 2000
setAccel(motorNum, MINACCEL)
onMotor(motorNum)
repeat while long[posPtr] < (newPos - 2000)
setAccel(motorNum, MAXACCEL)
rampSpeed(motorNum, speed, MINSPEED)
repeat while long[posPtr] < newPos
offMotor(motorNum)
setAccel(motornum, curAccel)
PRI moveXY(x1, y1) | posXptr, posYptr, motor1, motor2, curSpeed1, curSpeed2, accel1, accel2
motor1 := 1
motor2 := 2
posXptr := @motorData[(motor1-1) * motorArraySIZE+ arrayPOSITION]
posYptr := @motorData[(motor2-1) * motorArraySIZE+ arrayPOSITION]
if x1 < 0
reverseMotor(motor1)
x1 := -x1
else
forwardMotor(motor1)
if y1 < 0
reverseMotor(motor2)
y1 := -y1
else
forwardMotor(motor2)
onMotor(motor1)
onMotor (motor2)
repeat
if long[posXptr] > (x1 - 2000)
curSpeed1 := motorData[(motor1-1) * motorArraySIZE + arraySPEED]
rampSpeed(motor1, curSpeed1, MINSPEED)
if long[posYptr] < (y1 - 2000)
curSpeed2 := motorData[(motor2-1) * motorArraySIZE + arraySPEED]
rampSpeed(motor1, curSpeed2, MINSPEED)
if long[posXptr] > x1
offMotor(motor1)
if long[posYptr] > y1
offMotor(motor2)
if (isOn(motor1) == 0) AND (isOn(motor2) == 0)
quit
setSpeed(motor1, curSpeed1)
setSpeed(motor2, curSpeed2)
Exactly what behavior are you seeing? Perhaps the program is affected by a power cycle and you're not power cycling when you download the program into RAM to run, but you might be power cycling when you download and run the program from EEPROM.
I am using SimpleIDE to load programs. If I load to to EEPROM the program will not execute. When I load to RAM it runs. Is this just normal behavior?
I've not had problems with SimpleIDE on a Mac.
The funny thing is I do not recall this behavior from SimpleIDE in the past. I presumed I had somehow implemented a memory usage scheme that became problematic with the enhanced SerialDriver4port object.
