Help interfacing Altimeter MS5607 with Arduino SPI - From the I2C
Hello, I'm stucked in this issue 3 months ago, I really need help, this is the problem, I have to connect the Altimeter MS5607 with my Arduino UNO and using SPI, after trying so many times, I'm really MAD! haha
I think there is a way if I start from the I2C code (I'll paste the example for I2C that works):
I really need it to be using SPI Protocoll
2 files, Altimeter_Arduino_10.ino
and IntersemaBaro.h
Can anyone help me on this one? I dont know where to get help. Thank you very much
#include <Wire.h>#include "IntersemaBaro.h"
Intersema::BaroPressure_MS5607B baro(true);
void setup() {
Serial.begin(9600);
baro.init();
void loop() {
int alt = baro.getHeightCentiMeters();
Serial.print("Centimeters: ");
Serial.print((float)(alt));
Serial.print(", Feet: ");
Serial.println((float)(alt) / 30.48);
delay(400);
and IntersemaBaro.h
// http://code.google.com/p/ardroneme/// From the file NavData2.zip
/* Updated by MAPGPS based on Richi's code:
* http://ulrichard.is-a-geek.net/?p=23
//Update by boulderjoe 12/30/11 to work with arduino 1.0
#ifndef INTERSEMA_BARO_H
#define INTERSEMA_BARO_H
#include <Wire.h>
#include <util/delay.h>
#include "Arduino.h"
namespace Intersema
class BaroPressure
public:
virtual void init() = 0;
int32_t getHeightCentiMeters(void)
return AcquireAveragedSampleCm(NUM_SAMP_FOR_AVG);
protected:
virtual int32_t AcquireAveragedSampleCm(const uint8_t nSamples) = 0;
virtual uint32_t ConvertPressureTemperature(uint32_t pressure, uint32_t temperature) = 0;
int32_t PascalToCentimeter(const int32_t pressurePa)
// Lookup table converting pressure in Pa to altitude in cm.
// Each LUT entry is the altitude in cm corresponding to an implicit
// pressure value, calculated as [PA_INIT - 1024*index] in Pa.
// The table is calculated for a nominal sea-level pressure = 101325 Pa.
static const int32_t PZLUT_ENTRIES = 77;
static const int32_t PA_INIT = 104908;
static const int32_t PA_DELTA = 1024;
static const int32_t lookupTable[PZLUT_ENTRIES] = {
-29408, -21087, -12700, -4244, 4279,
12874, 21541, 30281, 39095, 47986,
56953, 66000, 75126, 84335, 93628,
103006, 112472, 122026, 131672, 141410,
151244, 161174, 171204, 181335, 191570,
201911, 212361, 222922, 233597, 244388,
255300, 266334, 277494, 288782, 300204,
311761, 323457, 335297, 347285, 359424,
371719, 384174, 396795, 409586, 422552,
435700, 449033, 462560, 476285, 490216,
504360, 518724, 533316, 548144, 563216,
578543, 594134, 609999, 626149, 642595,
659352, 676431, 693847, 711615, 729752,
748275, 767202, 786555, 806356, 826627,
847395, 868688, 890537, 912974, 936037,
959766, 984206};
if(pressurePa > PA_INIT)
return lookupTable[0];
else
const int32_t inx = (PA_INIT - pressurePa) >> 10;
if(inx >= PZLUT_ENTRIES - 1)
return lookupTable[PZLUT_ENTRIES - 1];
else
const int32_t pa1 = PA_INIT - (inx << 10);
const int32_t z1 = lookupTable[inx];
const int32_t z2 = lookupTable[inx+1];
return (z1 + (((pa1 - pressurePa) * (z2 - z1)) >> 10));
static const uint8_t NUM_SAMP_FOR_AVG = 4;
unsigned int coefficients_[6];
class BaroPressure_MS5607B : public BaroPressure
public:
/// @param CSB i2c address select
BaroPressure_MS5607B(bool CSB = false) : i2cAddr_((CSB ? 0xEC : 0xEE) >> 1) { }
void init()
ResetSensor();
ReadCoefficients();
private:
const uint8_t i2cAddr_;
static const uint8_t cmdReset_ = 0x1E;
static const uint8_t cmdAdcRead_ = 0x00;
static const uint8_t cmdAdcConv_ = 0x40;
static const uint8_t cmdAdcD1_ = 0x00;
static const uint8_t cmdAdcD2_ = 0x10;
static const uint8_t cmdAdc256_ = 0x00;
static const uint8_t cmdAdc512_ = 0x02;
static const uint8_t cmdAdc1024_ = 0x04;
static const uint8_t cmdAdc2048_ = 0x06;
static const uint8_t cmdAdc4096_ = 0x08;
static const uint8_t cmdPromRd_ = 0xA0;
void ResetSensor()
Wire.begin();
Wire.beginTransmission(i2cAddr_);
Wire.write(cmdReset_);
Wire.endTransmission();
delay(3);
void ReadCoefficients(void)
for(uint8_t i=0; i<6; ++i)
coefficients_[i] = ReadCoefficient(i + 1);
#ifdef DEBUG
Serial.print("Coefficient ");
Serial.print(i + 1, DEC);
Serial.print(" : ");
Serial.println(coefficients_[i], DEC);
Serial.println(ConvertPressureTemperature(6074082, 8574974));
Serial.println(ConvertPressureTemperature(6074082, 8574984));
#endif
uint16_t ReadCoefficient(const uint8_t coefNum)
uint16_t rC=0;
Wire.write(cmdPromRd_ + coefNum * 2); // send PROM READ command
Wire.requestFrom(i2cAddr_, static_cast<uint8_t>(2));
if(Wire.available() >= 2)
uint16_t ret = Wire.read(); // read MSB and acknowledge
uint16_t rC = 256 * ret;
ret = Wire.read(); // read LSB and not acknowledge
rC = rC + ret;
return rC;
#ifdef DEBUG
else
Serial.println("No data available in ReadCoefficient()");
#endif
return 0;
int64_t pressAccum = 0;
for(size_t n = nSamples; n; n--)
const uint32_t temperature = ReadAdc(cmdAdcD2_ | cmdAdc4096_); // digital temperature value : typical 8077636
const uint32_t pressure = ReadAdc(cmdAdcD1_ | cmdAdc4096_); // digital pressure value : typical 6465444
const uint32_t pressConv = ConvertPressureTemperature(pressure, temperature);
pressAccum += pressConv;
//MAPGPS
Serial.print("pressure: ");
Serial.print(pressure, DEC);
Serial.print(", pressConv: ");
Serial.print(pressConv, DEC);
Serial.print(", temperature: ");
Serial.println(temperature, DEC);
const int32_t pressAvg = pressAccum / nSamples;
const int32_t AltCm = PascalToCentimeter(pressAvg);
return AltCm;
int32_t ReadAdc(const uint8_t cmd)
Wire.write(cmdAdcConv_ | cmd); // send conversion command
// wait necessary conversion time
switch(cmd & 0x0f)
case cmdAdc256_:
delay(1);
break;
case cmdAdc512_:
delay(3);
break;
case cmdAdc1024_:
delay(4);
break;
case cmdAdc2048_:
delay(6);
break;
case cmdAdc4096_:
delay(10);
break;
Wire.write(cmdAdcRead_);
Wire.requestFrom(i2cAddr_, static_cast<uint8_t>(3));
if(Wire.available() >= 3)
uint32_t temp = 65536 * ret;
ret = Wire.read(); // read byte and acknowledge
temp = temp + 256 * ret;
temp = temp + ret;
return temp;
#ifdef DEBUG
else
Serial.println("No data available in cmdAdc()");
#endif
return 0;
// calcualte 1st order pressure and temperature (MS5607 1st order algorithm)
const int32_t dT = temperature - coefficients_[4] * 256; // difference between actual and reference temperature
//const int32_t temp = (2000 + (dT * coefficients_[5]) / pow(2, 23)) ; // / 100; // actual temperature
//const int64_t OFF = static_cast<int64_t>(coefficients_[1]) * pow(2, 17) + dT * coefficients_[3] / pow(2, 6); // offset at actual temperature
//const int64_t SENS = static_cast<int64_t>(coefficients_[0]) * pow(2, 16) + dT * coefficients_[2] / pow(2, 7); // sensitivity at actual temperature
//const int32_t press = ((pressure * SENS / pow(2, 21) - OFF) / pow(2, 15)); // / 100; // temperature compensated pressure
//MAPGPS: adapt formulas to avoid overflow
const int32_t OFF = coefficients_[1] * 4 + ((float)dT / 2048) * ((float)coefficients_[3] / 1024);
const int32_t SENS = coefficients_[0] * 2 + ((float)dT / 4096) * ((float)coefficients_[2] / 1024);
const int32_t press = ((float)pressure / 2048) * ((float)SENS / 1024) - OFF;
Serial.println();
Serial.println(dT, DEC);
Serial.println(OFF, DEC);
Serial.println(SENS, DEC);
Serial.println();
return press;
} // namespace Intersema
#endif
