gcc toolchain on Ubuntu and quickstart board -- success
Built various demos on Ubuntu 12.04 with QuickStart board. Here is simple C program to read buttons and turn on touched LEDs.
I got all of the fibo demos to work excpet xmm?? -- it loaded but nothing was printed to terminal ?? (xmmc worked)
Here are some simple "speed" tests.
How fast can I read CNT (e.g. t1=CNT; t2= CNT-t1; )
recursive fibonacci (fibo(26))
// quickstart board resistive buttons 0-7 LEDs 16-23
// bring pad HIGH, touching button brings it LOW
#include <propeller.h>
#define BUTTONS (0xff)
#define LEDS (0xff<<16)
int main() {
DIRA |= BUTTONS | LEDS; // output
OUTA |= BUTTONS; // bring high
while(1) {
DIRA |= BUTTONS; // output
DIRA &= ~BUTTONS; // input mode
waitcnt(CNT + CLKFREQ/1000); // ms wait
OUTA &= ~LEDS; // clear LEDs
OUTA |= ((~( INA & BUTTONS)) << 16) & LEDS; // in,flip,shift,mask
return 0;
gcc 16 cycles
catalina-3.6 112 cycles (with external CNT)
spin 368 cycles
presumably PASM could do it in 4 cycles.
spin 368 cycles
catalina 3.6 5342 ms
gcc cog 486 ms
gcc lmm 927 ms
arduino uno (16MHz) 32-bit int's 927 ms
maple (72MHz) 104 ms
beaglebone (720MHz) 8.2 ms
ubuntu/i3-2370M (2.4GHz) 1.2ms
MD5 (KBs == 1024 bytes/second)
gcc cog 486 ms
gcc lmm 927 ms
spin 7 KBs catalina 84 KBs gcc 222 KBs (lmm)
arduino 48 KBs
maple 1937 KBs
beaglebone 13755 KBs
ubuntu 187958 KBs
arduino 48 KBs
maple 1937 KBs
ubuntu 187958 KBs
--Steve
http://www.ietf.org/rfc/rfc1321.txt
spin code http://obex.parallax.com/objects/321/
gcc 47ms
catalina-3.6 410ms
arduino UNO can't do it (only 2K sram)
maple 8 ms
beaglebone 0.375 ms (had to do it 1000 times to exceed a ms, then divide out 1000)
ubuntu 0.053ms (needed 1000 iterations)
