Basic stamp project - Alarm device with motor output
Hi,
I am currently doing a project on automated pill machine, which i have bought the basic stamp discovery kit, stepper motor, DS1302 time keeping chip for it. Probably very new to these stuff, so really do hope to get some help from here.
1) For Board of education, the recommended power supply is the 7.5V/1A but how do I work about it to support the 12V Stepper motor? I was thinking that I might need the ULN2803A Darlington Array to work with it? And would that be the only way to go about?
2) The functions of this device works like when the alarm time reaches the time it is now, it lights the LED, sounds the buzzer and moves the motor, each action has its own source codes that I could find in Parallax web itself. However, just like to ask how would the integration of these codes be performed.. Like, how do I make it like an alarm clock? Where once timing is reached, it triggers 3 outputs.
Thanks!
Thanks!
You will need to work through the exercises in the "What's a Microcontroller?" tutorial. As you've noticed, programs for complex functions tend to be made up of simpler functions combined together. Look at the Nuts and Volts Columns. Go through the StampWorks Manual. Work through the What's a Microcontroller tutorial. The exercises are intended to show you how the various pieces work and how to combine them and modify them as needed.
However, how about the writing for an alarm system? I am using the LCD Appmod Terminal, which I find it quite different from the normal Parallel LCD. I have seen the LCD_AppMod_Demo.BS2 but it isnt too much of a help as for my alarm system I would require it to
1) Set alarm time using the 4 buttons available on LCD Appmod itself
2) Store the alarm
3) Countdown to the alarm set.
Is there any similar source codes that I could refer from that is for LCD Appmod Terminal??
As you're learning how to program with the Stamp, be sure to look through the Nuts and Volts Columns. They're a great source of practical coding examples.
Check out www.GarageDoorValet.com for a some sample code that may give you some insight. I have not used the LCD Appmod buttons or remember looking at it, but my site may help you, with some sample code and design. I have more sample code (to be posted) for use with an Parallax 2 Line LCD Backlit. This code may be stripped down to fit in a BS2 but I wrote it for the BS2e with multiple ram slots. See site and if you think it will help, let me know.
GDValet@gmail.com for PM
Howard
For the DS1302 Time keeping chip, managed to get that working too. However, the setting of alarm on my LCD appmod seems to be in stuck. I tried editing from the QuadRodLCD code that MIke directed me to it, it gets stuck at the very end though cause it couldnt return back to setting another timing. Also I am wondering if the way I store my value is correct, so that when it is working together with the DS1302, say when Hour1 =hrs & Min1 =mins, (hrs and mins are defined in the DS1302 source codes), it would trigger the output.. am i on the right track?
:Here is the code:
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
PSC PIN 15 ' PSC module
' ----[ Set baud for all STAMP versions ]
#SELECT $STAMP
#CASE BS2SX, BS2P
Baud CON 1021 + $8000
#CASE BS2PX
Baud CON 1646 + $8000
#CASE #ELSE
Baud CON 396 + $8000
#ENDSELECT
[ LCD I/O Definitions ]
E PIN 1 ' LCD Enable (1 = enabled)
RW PIN 2 ' Read/Write
RS PIN 3 ' Reg Select (1 = char)
LcdDirs VAR DIRB ' dirs for I/O redirection
LcdBusOut VAR OUTB
LcdBusIn VAR INB
#DEFINE _lcdReady = ($stamp = BS2SX) OR ($stamp = BS2P)
LcdCls CON $01 ' clear the LCD
LcdHome CON $02 ' move cursor home
LcdCrsrL CON $10 ' move cursor left
LcdCrsrR CON $14 ' move cursor right
LcdDispL CON $18 ' shift chars left
LcdDispR CON $1C ' shift chars right
LcdDDRam CON $80 ' Display Data RAM control
LcdCGRam CON $40 ' Character Generator RAM
LcdLine1 CON $80 ' DDRAM address of line 1
LcdLine2 CON $C0 ' DDRAM address of line 2
LcdScrollTm CON 250 ' LCD scroll timing (ms)
'---- [Alarm Variables]
ptrEEPROM VAR Word ' Gait select
Alarm1 VAR Byte ' Servo addresses
Hour1 VAR Byte ' Right side ramp values
Min1 VAR Byte
rowCounter VAR Nib ' Count EERROM rows
[ LCD Variables ]
counter VAR Byte ' Loop counter
char VAR Byte ' Character sent to LCD
value VAR Byte ' Increment Decr. value
menu VAR Nib ' Current menu
buttons VAR Nib
btnA VAR buttons.BIT0 ' left-most button
btnB VAR buttons.BIT1
btnC VAR buttons.BIT2
btnD VAR buttons.BIT3 ' right-most
[EEPROM DATA ]
'LCD EEPROM Data
'Smiley DATA $00, $0A, $0A, $00, $11, $0E, $06, $00 ' 0 smiley
'DownArrow DATA $04, $04, $04, $04, $1F, $0E, $04, $00 ' 1 Down Arrow
UpArrow DATA $04, $0E, $1F, $04, $04, $04, $04, $00 ' 2 Up Arrow
'C_Gear DATA $06, $0F, $09, $18, $18, $09, $0F, $06 ' 3 char1 C Gear
Enter DATA $01, $01, $01, $05, $0D, $1F, $0C, $04 ' 4 Enter Arrow
EndCG DATA $00
Msg1 DATA "Drug ",0
Msg2 DATA "Dispenser",0
'Msg3 DATA "PING))) ",0
'Msg4 DATA "RC ",0
AlarmNo DATA "Alarm ",0
Hour DATA "Hour: ",0
Minute DATA "Min: ",0
'Distance DATA "Dist:",0
GUI DATA "m ", 2, " ",1," ", 4, 0
'_________________________________________________________________________
' 0 = normal mode
' 1 = debug mode
#DEFINE debugMode = 0
Initialize:
GOSUB Initialize_LCD ' Initialize LCD
PAUSE 500 ' Wait 1/2 sec
menu = 0
GOTO Menus ' Center legs
'Clear Screen
' Write UI
' Loop until button D is pressed
' Increment/Decrement value
' Convert value to ASCII by adding 48
'Parameters ()
'Return ()
Menus:
char = LcdCls ' Clear command
GOSUB LCD_Command ' Write clear screen command
GOSUB Write_GUI ' Write Graphic Interface
Get_Menu:
char = LcdHome ' Cursor to home position
GOSUB LCD_Command
IF menu = 0 THEN GOTO Alarm_Menu
IF menu = 2 THEN GOTO Minute_Menu
Hour_Menu:
ptrEEPROM = Hour ' Point to Direction string
GOSUB LCD_Put_String ' Write String
PAUSE 100 ' Wait
value = Hour1 ' Input param direction
GOTO Incr_Decr ' Skip
Alarm_Menu:
ptrEEPROM = AlarmNo ' Point to Speed string
PAUSE 100 ' Wait
value = Alarm1 ' Input param ramp
Minute_Menu:
ptrEEPROM = Minute ' Point to Speed string
PAUSE 100 ' Wait
value = Min1 ' Input param ramp
Incr_Decr:
DO WHILE btnD = 0 ' Do while D not pressed
GOSUB LCD_Get_Buttons ' Check button pressed
IF btnB THEN ' B pressed?
SELECT menu
CASE 0
value = (value + 1) // 4
CASE 1
value = (value + 1) // 25
CASE 2
value = (value + 1) // 60
ENDSELECT
ENDIF
'IF btnC THEN ' C Pressed
' SELECT menu
' CASE 0
' value = (value + 15) // 16
'CASE 1
' value = (value + 7) // 8
'CASE 2
' value = (value + 255) // 256
'ENDSELECT
'ENDIF
IF btnA = 1 THEN
menu = (menu + 1) // 3
GOTO Get_Menu
ENDIF
GOSUB Set_Value ' Assign ramp or direction
GOSUB Write_Num
PAUSE 75 ' Write number to LCD
LOOP
GOSUB Alarm_Logo
' Sets velocity, direction, and limiter values
' Parameters (menu)
' Return (vel, dir, limiter)
Set_Value:
SELECT menu
CASE 0
Alarm1 = value ' Set alarm
CASE 1
Hour1 = value ' Set hour
CASE 2
Min1 = value ' Set minutes
ENDSELECT
RETURN
' Gets velocity, direction, and liniter values
'Parameters (menu)
'Return (vel, dir, limiter)
Get_Value:
SELECT menu
CASE 0
value = Alarm1 ' Get alarm
CASE 1
value = Hour1 ' Get hour
CASE 2
value = Min1 ' Get minutes
ENDSELECT
RETURN
' Scan buttons
' Parameters ()
' Return (buttons)
LCD_Get_Buttons:
LcdDirs = %0000 ' make LCD bus inputs
buttons = %1111 ' assume all pressed
FOR counter = 1 TO 10
buttons = buttons & LcdBusIn ' make sure button held
PAUSE 5 ' debounce 10 x 5 ms
NEXT
LcdDirs = %1111 ' return bus to outputs
RETURN
' Position LCD cursor
' Conver the number in value to ASCII and write to the LCD AppMod
' Parameters (value)
' Return ()
Write_Num:
char = LcdLine1 + 5 ' Goto line 1 position 4
GOSUB LCD_Command
C_ASCII: ' convert to ASCII value
char = (value / 100) ' Get 100s position
value = (value //100) ' Get Mod
char = char + 48 ' Convert to ASCII
GOSUB Write_LCD_Char ' Write value
char = (value / 10) ' Get 10s position
value = (value // 10) ' Get Mod
char = value + 48 ' Convert to ASCII
GOSUB Get_Value
RETURN
' Write interface screen to LCD AppMod
' Parameters (char)
' Return ()
Write_GUI: ' Write GUI items on line 2
char = LcdLine2 ' Goto Line 2
GOSUB LCD_Command ' LCD Command
ptrEEPROM = GUI ' Write CG chars (menu items)
GOSUB LCD_Put_String ' Write characters
RETURN
' Read EEPROM data and write it to the LCD
' Parameters (ptrEEPROM)
' Return ()
LCD_Put_String:
DO
READ ptrEEPROM, char ' Read data at EEPROM address
IF (char = 0) THEN EXIT ' 0 = End of EEPROM String
GOSUB Write_LCD_Char ' Write character to LCD
ptrEEPROM = ptrEEPROM + 1 ' Increment EEPROM pointer
LOOP
RETURN
' Write LCD command/Write Character
' Parameters (char)
' Return ()
LCD_Command: ' write command to LCD
#IF _LcdReady #THEN
LCDCMD E, char
RETURN
#ELSE
LOW RS
GOTO Write_LCD_Char
#ENDIF
Write_LCD_Char: ' write character to LCD
#IF _LcdReady #THEN
LCDOUT E, 0, [char]
#ELSE
LcdBusOut = char.HIGHNIB ' output high nibble
PULSOUT E, 3 ' strobe the Enable line
LcdBusOut = char.LOWNIB ' output low nibble
PULSOUT E, 3
HIGH RS ' return to character mode
#ENDIF
RETURN
' Initialize LCD
' Write custom characters to the LCD
' Write CrustCrawler Banner
' Parameters ()
' Return ()
Initialize_LCD:
#IF _LcdReady #THEN
LCDCMD E, %00110000 : PAUSE 5 ' 8-bit mode
LCDCMD E, %00110000 : PAUSE 0
LCDCMD E, %00100000 : PAUSE 0 ' 4-bit mode
LCDCMD E, %00101000 : PAUSE 0 ' 2-line mode
LCDCMD E, %00001100 : PAUSE 0 ' no crsr, no blink
LCDCMD E, %00000110 ' inc crsr, no disp shift
#ELSE
NAP 5 ' let LCD self-initialize
DIRL = %11111110 ' setup pins for LCD
LcdBusOut = %0011 ' 8-bit mode
PULSOUT E, 3 : PAUSE 5
PULSOUT E, 3 : PAUSE 0
LcdBusOut = %0010 ' 4-bit mode
PULSOUT E, 3
char = %00101000 ' 2-line mode
GOSUB LCD_Command
char = %00001100 ' on, no crsr, no blink
GOSUB LCD_Command
char = %00000110 ' inc crsr, no disp shift
#ENDIF
ClearScreen:
char = LcdCls ' Clear screen
GOSUB LCD_Command
Download_Chars: ' download custom chars
char = LcdCGRam ' point to CG RAM
GOSUB LCD_Command ' prepare to write CG data
FOR counter = UpArrow TO EndCG-1 ' build custom chars
READ counter, char ' get byte from EEPROM
GOSUB Write_LCD_Char ' put into LCD CG RAM
NEXT
Alarm_Logo: ' Dispaly CC logo
char = LcdLine1 ' Line 1
GOSUB LCD_Command
ptrEEPROM = Msg1 ' Message 1 pointer
GOSUB LCD_Put_String ' Write string
char = LcdLine2 ' Go to Line 2
GOSUB LCD_Command ' Write command
ptrEEPROM = Msg2 ' Point to message 2
RETURN
' Writes variables to the debug terminal when DebugMode = 1
' Copy and paste the Debug tool to strategic location in the code. This
' allow you to see each variable in the Trace sub.
'DEBUG Tool
#IF debugMode #THEN
GOSUB Trace
#ENDIF
' Write trace information
' to debug terminal
#IF debugMode #THEN
Trace:
DEBUG CLS, "Buttons: ", BIN buttons, CR,
RETURN
#ENDIF
